09-27-2006, 07:02 PM
Help!
Hello guys and gals I've been lurking here for a few weeks and just signed up. Seems to be an awsome forum to be apart of. I've had my H3 for about 3 wks now and I need some help. I need access to the audio wires but I can't figure out how to get the dang dash/audio piece off! Can anyone shine some light on this for me? Thanks much.
09-27-2006, 07:14 PM
Re: Help!
Move the shifter all the way back, disconnect the battery, stick your fingers in the lighter sockets and pull out and up. Its just held in with clips.
09-27-2006, 07:18 PM
Re: Help!
...and was looking in the vents for screws and all sorts of stuff. lol thanks your a live saver...
09-27-2006, 10:52 PM
Re: Help!
Do you have to disconect the battery.
I had it off several times I never disconected the battery.
09-27-2006, 11:04 PM
Re: Help!
Don't you know, if you stick you fingers in the holes without disconnecting the battery you'll get electrocuted. You lucky to still be alive
09-27-2006, 11:22 PM
Re: Help!
Nah ! only 12 volts
09-27-2006, 11:46 PM
Re: Help!
what's that burning smell?
09-27-2006, 11:53 PM
Re: Help!
Using the plugs is one way, slightly prying at the top with a plastic tool then grabbing hold of the panel and pulling back works too.
09-28-2006, 12:24 AM
Re: Help!
Probably not necessary, but I don't want to be the one that gets him zapped.
When I took mine off it was to install my CB. I always play it safe and disco the power when I'm doing electrical work, even low voltage.
09-28-2006, 02:13 AM
Re: Help!
Nah ! only 12 volts
Its not the volts that kill its the amps/current.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
09-29-2006, 01:32 AM
Re: Help!
Exactly, I learned the saying "Volts Jolt, Amps Kill." This is true.
09-29-2006, 01:55 AM
Re: Help!
The worst thing that can happen is seeing your fingertips glowing red hot, just like a couple of cigar lighters. If you smoke, first light up your stogey with your fingers (pretty cool), then come see me.
09-29-2006, 10:45 AM
Re: Help!
AMPS are the killer...unless the voltage jolt causes a muscle contraction that triggers a secondary reaction. Years ago I read that about 25 percent of people who die due to electricity are killed from a secondary hit from the initial jolt of electricity. They take the jolt, muscles contract and they fly back against something hard; usually with the head. I believe that at times the muscle reaction can be the heart, causing some type of heart attack.
