Old 01-13-2006, 03:50 PM
just ordered the hypertech power programmer, i was wondering what settings i will be changing and the options i will have, so if anyone has any info let a brother know!!!!! iam running 37x13.50 r 18 nitto mudd grapps , the main reason i got the programmer
Old 01-13-2006, 04:12 PM
rodster rodster is offline
rodster is off the scale
Here's mine. It likely won't make much sense until you have the programmer.
These were the initial settings recommended by Trail Duty, where I got the Hypertech programmer. I haven't changed them since the initial programming and doubt I will. The truck runs great and my speedometer is dead-on accurate after installing tires the same size as yours.
Program: 87 Octane
Gear Ratio: Stock
Tire Height: I forgot
Shift Point 1-2: Min - X - - SC - - - - Max
Shift Point 2-3: Min - X - - SC - - - - Max
Shift Point 3-4: Min - - X - SC - - - - Max
Shift Pressure 1-2: Min - - - - SC - - X - Max
Shift Pressure 2-3: Min - - - - SC - - X - Max
Shift Pressure 3-4: Min - - - - SC - X - - Max
Speed Limiter: Stock
Rev Limiter: Stock
\'05 SUT
Old 01-13-2006, 04:38 PM
Ernie Italy is off the scale
Shift pressure on Hypertech power programmer ?? I have it but dont found this setting... only increase shift firmness
Old 01-13-2006, 04:48 PM
Here this should help.
http://elcova.com/groupee/forums/a/tpc/f/5106011751/m/6.../602107297#602107297
I just got a SuperChips over the Holidays, and I've been playing with the different settings. I like the shift pressure settings of Tim's, but I may bump it up even more. He ran 37" tires too. It's a good start.
Old 01-14-2006, 02:42 AM
very much appreciate the info, as i am the furthest thing from "gearhead" as u can get, i got the hummer cuz it fits me good and now im gettin in a little deep lol
Old 01-14-2006, 02:52 AM
The programmer comes with very good step-by-step instructions. Just follow them and you'll do fine.
The only pain in the butt part is you have to pull your OnStar fuse while you're programming. That fuse is in the fuse box in the engine bay on the driver side, just aft of the battery. Look in your owner's manual for which fuse is OnStar. As I recall, it's in or near the lower right corner of the fuse box if you're looking in from the driver's side of the truck.
Whatever settings you choose to start with, it's best to have them printed and with you when you start the programming. Before I started, I read the thread that H2 Rocks posted a link to. That got me confused so I asked Phil at Trail Duty what he recommends. The settings I used are the same he uses.
The whole operation should take you about 15 minutes the first time. After that, well under 10. You'll likely change the tire size a few times to get it right.
\'05 SUT
Old 01-14-2006, 05:16 PM
Same thing, but rodster is talking about SuperChips I think. </div></BLOCKQUOTE>
My bad. You are correct, mine is SuperChips.
\'05 SUT
Old 01-14-2006, 05:43 PM
If your running the stock size tires is there really any advantage to using a programmer? Which is better Hypertech or Superchips? They both seem to do the same thing with the same results from reading their webpages.
Old 01-15-2006, 03:56 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Rod/Phil, does moving the shfit point lower as you indicated cause the tranny to shift into the next higher gear sooner or later than normal? I think I may have goofed on this one when I set mine up.
Thanks,
Pete
Old 01-17-2006, 11:54 PM
TXSUT's Avatar
Thanks Phil, much appreciated as always.
-Pete
Old 01-18-2006, 02:08 AM
rvs9 rvs9 is offline
rvs9 is off the scale
Wished I'd known that you were looking at the Hypertech. I have a brand new one that is sitting in my garage. Didn't need it when I opted for the supercharger.
Old 01-18-2006, 04:31 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TXSUT:
-Pete
My doctor said I have A.D.D., but he's wrong...hey look, a chicken! </div></BLOCKQUOTE>
Ya know, Pete, I've been thinking that there's a lack of congruency between your avatar and your signature. I just can't picture a Confederate flag-waiving rebel with A.D.D.
In the midnight hour she cried- "more, more, more"
With a rebel yell he cried- "more, more, mo ... hey, HEY, HEY you see that thar chick-uhn!?!
\'05 SUT
Old 01-18-2006, 11:52 AM
TXSUT's Avatar
Well, Rod, the Confederate flag is a joke that applied a few weeks ago where I was pretending to be racist. After 5 years of being a message board junkie (all sportbike/motorcycle racing related), I'm getting old and tired, and have a hard time these days with keeping everything in sync.
Old 12-14-2006, 07:39 AM
JDLarue's Avatar
JDLarue JDLarue is offline
JDLarue is on a distinguished road
Default Re: just ordered hypertech
Rod, can u explain what Min X SC Max is? I've got the programmer and that doesn't make any sense to me. When I talked to the Hypertech tech he told me to set the rev limiter at 6100 rpm and set the shift points to 1-2 +200
2-3 +400
3-4 +500
I'm really confused about your settings.
2003 H2 Lux series, Pewter (I know...non-color) Airaid intake system, Granitelli MAF, Hypertech III programmer, sun roof, brush guard, a little billet bling, air suspension, 37x13.5x17 Toyo M/T's on stock chrome rims, 06 mirrors, like to get a 6" Fabtech lift but couldn't get it in the garage, other than that...pretty much stock.
Old 12-14-2006, 02:57 PM
TXSUT's Avatar
2-3 +400
3-4 +500
You have the Hypertech programmer and Rod has the Superchips programmer, so his settings don't apply to your issue. For what it's worth, though, his "X's" show where he placed his settings in the range between minimum and maximum. To illustrate, where he says "Shift Point 1-2: Min - X - - SC - - - - Max" means he selected the position that is 2 clicks above the minimum value.
Old 12-14-2006, 06:47 PM
JDLarue's Avatar
OK, thnx TX.
