Old 02-11-2007, 07:10 PM
Klint's Avatar
Klint Klint is offline
Default 6in lift?
I want to put about 6in lift and 35's on. Who makes a lift that's not to much $$$
Klint T.
2007 Black Lux, Blinged out
Old 02-11-2007, 07:16 PM
Klint's Avatar
Default Re: 6in lift?
I found this - http://www.suspensionconnection.com/...?mv_pc=froogle
which is a 4in is that 4in front and back? if so do I need or could I also get a leveling kit and add it on?
Klint T.
Old 02-11-2007, 08:05 PM
No, there is more lift in the front than the back with both this lift and the Rancho. Also, depending on what backspace you have on your new wheels, you may have to replace them again with either lift.
Old 02-11-2007, 08:49 PM
the tough country looks like a rip off on the rancho kit , you cant use stock wheels
Old 02-11-2007, 08:51 PM
Klint's Avatar
why is that, also I dont use stock wheels or tires...
Klint T.
Old 02-11-2007, 08:52 PM
Klint's Avatar
also we are talking about over $1000 dif so is it that big of a ripoff?
Klint T.
Old 02-11-2007, 08:53 PM
i just checked the RC site . check out what it said for the H3 lift .
This kit is currently being redesigned.
Please check back here for updates or contact us, 1-800-222-7023.
RC =
remember when we all went nutz for this kit
Old 02-11-2007, 08:55 PM
looks like the tough country is the same for a much better price
Old 02-11-2007, 08:56 PM
heres the RC linky
http://roughcountry.com/hummer_h3.html
Old 02-11-2007, 09:59 PM
The way the kits are designed you need a wheel with less backspacing, and sometimes increased diameter.
Old 02-11-2007, 10:21 PM
Klint's Avatar
tough country do they make something around the $1400 price range?
Klint T.
Old 02-11-2007, 11:21 PM
you will need shocks with the kit , so check with 4-wheel parts they sometimes run free shock promotions with their lift kits . i think you found the most economical one available now . the rancho is probably the best available now . Keep shoppin !!!!
Old 02-11-2007, 11:28 PM
http://www.suspensionconnection.com/...on/140401.html
this one has just the add-a-leaf for the rear
Old 02-16-2007, 07:11 AM
Klint's Avatar
So this is a good deal?
Klint T.
Old 02-16-2007, 07:41 AM
Just curious, what's the reason for wheels with less backspacing on the lift kits?
Old 02-16-2007, 08:30 AM
Haven't seen one in person, but I'm guessing there's some clearance issues with the brakes and new knuckles due to some geometry changes. Here's Rancho's wheel guide for the lift from their site.
Maybe someone with the lift can shed some more light.
Old 09-18-2007, 11:12 PM
subunix's Avatar
subunix subunix is offline
subunix is on a distinguished road
RC =
Yeah its still like that today
"We don't do pretty"
Old 09-20-2007, 04:40 AM
H3_ATX_BLK's Avatar
H3_ATX_BLK H3_ATX_BLK is offline
H3_ATX_BLK is on a distinguished road
Unhappy Re: 6in lift?
Ok What is backspacing? I know, I know berate me as you answer my question lol.
2007 H3 BAM-BAM in Black
Old 09-20-2007, 03:57 PM
waynesoffroad's Avatar
waynesoffroad waynesoffroad is offline
waynesoffroad is on a distinguished road
I just installed a 4" Rancho on mine. Took me about six hours. The kit is really well made and rides much beter then it did when it was stock. I had to install a set of YJ boomerang shackles because I had clearance problems with my aftermarket hitch. It would have been fine with the factory hitch. With the extra lift from the shackles I had to crank the front trosion bars up to five inches. But you could get six if you wanted to. I'm running 35-12.50-18 Procomp Xtreme all terrains on 18x9 Moto Metal 955 with 4.52" of backspacing. You could run the stock wheels if you had some wheel spacers.
Old 09-20-2007, 04:04 PM
Attachment 36446
It's because of the spindles, The lip of the rim rubs on it. You would need bout a 1.5" wheel spacer to use the stock wheels.
