Old 03-05-2007, 09:08 PM
sc2178's Avatar
sc2178 sc2178 is offline
sc2178 is on a distinguished road
Default has anyone used Surco roof cross bars??
I've seen people using the Surco racks, but what about crossbows? They are like $70/pair plus the $50 brackets to mount to the roof rails.
Does anyone know if they fit well? I am looking for something to just put up there to mount a high lift jack to, instead of buying the GM roof crossbars.
can be seen here:
http://www.autoanything.com/roof-racks/69A2323A0A0.aspx
Thank you
Old 03-05-2007, 09:34 PM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Default Re: has anyone used Surco roof cross bars??
I used them with my Surco rack and they're ok. If you're looking to save a few bucks, they'll work fine. You have a small plate with two holes that you drop between the exisitng H3 rails. Use the screws to connect and tighten. No rattles, if that's what you were worried about. Also even though the parts are cheaper than stock, you'll feel like you spent too much when you put it together. After using both, I'm considering going back to the OEM ones or OEM "like" ones. I think Stallion Customs keeps a set on sale for the low $200's.....
Old 03-05-2007, 10:12 PM
sc2178's Avatar
Thank you for the input. Do you know how high they sit above the surface of the roof? Similar to the OEM ones? And do you have any pictures of them installed?
Old 03-06-2007, 10:45 PM
BradO's Avatar
They're higher than the OEM ones. I'll measure how high they rise above the roof tonight and post. Here's another thread that may be of interest and I have a couple of pics posted there. I also included one below:
http://www.elcovaforums.com/forums/s...ht=surco+urban
Old 03-07-2007, 01:33 AM
BradO's Avatar
4in from roof to the top of the bars.....
Old 03-07-2007, 05:57 PM
sc2178's Avatar
BradO - thank you for the pics and description. I really like how the crossbars look actually, a little more obvious than the OEM ones. Another Q - is it possible to mount a surco rack without the crossbars in between? Just mount it to the 4 adapters so it sits a bit lower?
Old 03-08-2007, 03:53 PM
BradO's Avatar
You could, but you would have to fab a flat piece to secure it. The existing mounts won't connect to the racks existing connection points. You would also lose any support to carry heavier items.
