Old 10-18-2007, 09:41 PM
boozmaster boozmaster is offline
boozmaster is on a distinguished road
Default 4.56 vs.4.88 w/6in. lift
i have an 06 w/ 6in lift, corsa exhaust, headers, airraid intake,and
hypertech lll programer. putting on 38.5x14.5x20 PROCOMP XTERRAINS Was wandering
which gears to go with and how much backspacing you guys use on new wheels.
I only get to do serious wheelin a few times a year other than that alot of city and hiway driving
THANKS
ALL OPINIONS ARE APPRECIATED
Old 10-19-2007, 02:21 AM
tomp's Avatar
tomp tomp is offline
Default Re: 4.56 vs.4.88 w/6in. lift
http://www.bncoffroad.com/ratio/
4.56:1 gears will get you close to stock
Old 10-19-2007, 02:53 AM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
The overall tire diamater is what will count the wheel size has no effect gear ratios. If you were to run 38" tires with a wheel back space of 4.5 inches (you can get by with 5 inch backspace) and a 6 inch lift it will look like mine. I would recommend that you consider carefully your choice of lift kit. Some highly recommended kits require Differential Mounts to be cut for clearance. Mine did not. So if you were to remove the kit later you wont run into another issue. Mine has the Corsa exhaust that you asked about as well. You can see another view
http://www.elcovaforums.com/forums/s...ad.php?t=30234
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 10-19-2007, 01:45 PM
hey tomp thanks for the site very beneficial. and H2R if 4.56 would be close to stock what would be the advantages and disadvantages of 4.88 i see alot of guys go with the 4.88 like yourself.
YHANKS GUYS
Old 10-19-2007, 01:49 PM
Hucky Hucky is offline
Thats sound advice right there, There are alot of Rigs running around lifted with cut parts and they will never go back to stock again, Choose your lift wisely!
Re-Sale Options to a potential buyer is huge.
Cheers
Old 10-19-2007, 03:15 PM
tomp's Avatar
Personally, I feel the H2 should have had 4:56 gears stock. Knowing that, I would go with the 4.88s with 38 tires.
Old 10-19-2007, 04:12 PM
Are you guys running Fabtech lifts? If not, what are you running?
I got a price of around $2000 for re-gearing my H2 from 4wheel parts. That seemed a little steep. When I do it I will be putting some better lockers in as well, so the cheaper the better!
1968 Mustang GT convertible
Old 10-19-2007, 08:17 PM
H2R's Avatar
H2R H2R is offline
[quote=Captain of the Titanic]Are you guys running Fabtech lifts? If not, what are you running?
Capt.,
I am using Bulletproof suspension with King offroad shocks. Both companys have excellent support services too.
http://www.bulletproofsuspension.net/
http://www.kingshocks.com/
The 2005-06 Rear Air Bag model H2 Hummer SUV's are coming equipped with a Non-Adjustable Ride Height Sensor. The K5001 will not work on these vehicles. At the current time, Fabtech does not make a kit for the 2005-06 H2 Hummers with rear air bag suspension. K5001 is only approved for the 2003-04 models that have the Adjustable Ride Height Sensors.
2013 Sierra Denali
2012 Yukon Denali
