09-09-2010, 05:10 PM
Re: Need some diff help!!
Originally Posted by twr
Hi is epc a one time buy or a yearly fee?
That's a good question. I believe there's an initial cost AND a yearly fee.
That said...I'm fairly certain that only an authorized GM dealer can purchase the software. I found a copy on the Internet a while back and pulled it down...not the most 'legal' of acquisitions, but neither was half of my mp3 collection.
CNTRY
DTOM
09-09-2010, 09:39 PM
its all good
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
09-10-2010, 12:05 AM
09-10-2010, 12:18 AM
Oh one more thing there was NO sealant on the diff when I split it I wonder why that is. The only reason why I was taking it apart was to fix a small leak on the diff. Is that normal? Also what is the best sealant to use for a sealant cause I have RTV Black but I have heard not to use that cause the synthenic oil will eat it up.
09-10-2010, 12:47 AM
I use the red hi temp one, but the black one is good to.
Missing the times when things where made to last.
09-10-2010, 12:51 AM
Hi it is a c" clip if your looks like a u" buy 2 new ones and Differential Carrier Assembly Case Mating Surfaces Sealant GM P/N 1052942 or any good RTV but make sure you read the directions on how long to let it sit before you put the halfs together.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
09-10-2010, 02:06 AM
Use a small file and clean any burrs around the c-clip grove and on any splines. This will make it easier to remove again if needed. Use anaroebic sealer on the case halves not sure if that is the part number twr has cause i dont know the part number off hand. If yu use silicone it will push out and eventually leak
1998 Chev Z71
2007 Chev Trailblazer SS
09-10-2010, 02:24 AM
Hi Humtech, that gm part # is anaroebic sealer, that is what gm uses on the case halfs in the USA, canda has a different part# but same sh-t.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
09-10-2010, 03:01 AM
Thanks I have the Permamek Black RTV which I was told is real good so I am going to use that plus stop at the dealer hopefully they have it stock. Is there a part number I can give them incase they are in deiet deiet mood.
09-10-2010, 03:10 AM
hi this is the sealer part #GM P/N 1052942
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
09-11-2010, 02:11 PM
Not to stir anything up or anything but since GM is not in the business of making sealant (we found out whats that all about with DIII episode) and it didn't work the first time when they sealed it, why would you expect a different outcome using a GM part#... again.
09-11-2010, 02:32 PM
Hi your right gm sealing products are not made by them, they are likely made by permatex or someone else in the business of sealing products. Also you are not stirring anything up. Some parts are machined surfaces and when car companys put things to together at first,[only some parts] they don't use any sealing compond because they think its perfect and won't leak. After being in service for awhile they realized they screwed up and some start to leak. Then it turns into a problem with recalls sometimes or a repair when the customer complains about a leak.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
09-11-2010, 09:04 PM
Well iused the Ultra Black cause I was thinking the same thing, It went on good and clean I removed any extra once it dried. Man its a PITA to get the diff in having problems putting it on the jack, but I will get it on there had to go ot town this weekend.
09-17-2010, 01:33 AM
use straps.
09-19-2010, 11:32 PM
RTV would always eventually leak on my front diff. Had to use GM anerobic stuff to get it to finally stop leaking
09-21-2010, 08:09 PM
I used RTV on my diff a year ago. no leaks at all. However I replaced my axle seals at the same time and now one of those is leaking. Its a VERY slow leak just enough to keep the diff wet but no pudling on the ground. What a PITA the H2 front diff is! lol
09-24-2010, 02:32 AM
Now I have a leak from the top I think its the vent tube, i suspect i filled the diff too much cause this never happened before. I mean it was a lot that came out I thought the diff was leaking then I looked at the top of driver side shock and noticed alot of fluid.
10-13-2010, 05:57 PM
I was just informed that my front axle seal is leaking and that the "axle spacer" from my lift is broken as well. I just bought the truck with a 6 inch fabtech lift. I looked on their website and can't find a replacement part section. Anybody know where to get this part from? Should I just write to fabtech?
