Old 09-07-2010, 02:46 AM
lx4life lx4life is offline
lx4life is on a distinguished road
Default Need some diff help!!
I talk to jarek m a ton, but I am still having diffcult time getting the inner shaft out, i think I might have broken something cause that thing won't come out. I really dont want to bother Jarek anymore so thats why i am coming to you guys. I have been hitting the hell out of it, but not really applying upward pressure since i dont know how would accomplish it.:twak : There has to be somthign holding it in there maybe a clip or something. I have attached a picture of what i am talking about the cicrcle is what I am having problems with. Is the half shaft(black piece) two different pieces which one is suppose to come out or does all of of come out.
Old 09-07-2010, 03:15 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Need some diff help!!
Trya prybar with outward pressure on the shaft and hit it straight in towards the diff with a big hammer. If it dont come out you will need to split the case and ry to pop the clip off he end of the shaft.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-07-2010, 03:19 AM
HUMTECH's Avatar
Hitting it straight back into the diff sometimes will center the retainer and allow it to pop out
1998 Chev Z71
Old 09-07-2010, 03:24 AM
How do I split the case? I am new to this but love learning new things when I can. Still kinda confused on the prybar thing where do i put teh pry bar to aplly the upward pressure plus be able to hit the shaft or am I suppose to hit the prybar I swear I am getting stupid by the minute.
Old 09-07-2010, 03:27 AM
HUMTECH's Avatar
Pry between the mount and the axle flange.
1998 Chev Z71
Old 09-07-2010, 03:34 AM
ok gotcha! I really think its stuck in there, but I will try again tomorrow. does it need to be unbolted from the diff. before I hit
Old 09-07-2010, 03:38 AM
HUMTECH's Avatar
Nope, it has a retaining ring that seats in a groove on the end. If that ring expands makes it very difficult to get out
1998 Chev Z71
Old 09-08-2010, 03:43 AM
Well i tried again today I think I am going to break something, I really need to see a breakdown instruction or something that hitting the shaft with a 8lbs hammer is kinda scaring me cause I really think I am going to break something. I am probably going to get a slide hammer so it even, I have heard you have to buy new rings, man this doesn't make since I would think there would be a inspection hole to where we can gain acesss to the pin in the spider or retaining clip.
Old 09-08-2010, 04:15 AM
jarek m's Avatar
jarek m jarek m is offline
jarek m is on a distinguished road
At the end of the shaft there is a spring that prevents the shaft from sliding out, you need to apply outward pressure on the shaft to get the spring inside the diff to align and then give it a hit with a 2.5er. Some springs don't come out in one piece there for hawing a new set handy is nice, my came right out, looks like yours are a little more stubborn that's all
This is a different application but the end of the spline looks same #1.
Missing the times when things where made to last.
Old 09-08-2010, 04:29 AM
jarek m's Avatar
Old 09-08-2010, 02:41 PM
YOU ARE THE MAN JAREK I WAS REALLY TRYING NOT TO BOTHER YOU!!!!! THANKS SO MUCH, its just that these things are so expensive to replace if I break it and I really don't want to go to the stealership and have them do it, cause I could use that money for aftermarket parts you know what I mean. This iste is one of the best around, I have to work until tomorrow afternoon(32hr work day) so i will try again tomorrow after work
Old 09-08-2010, 04:30 PM
jarek m's Avatar
It's no bother at all.
Old 09-08-2010, 05:47 PM
twr's Avatar
twr twr is offline
hi this should help you out with the front diff.
1 - Front Drive Axle Inner Shaft
2 - Front Drive Axle Inner Shaft Retaining Ring
3 - Front Drive Axle Inner Shaft Seal
4 - Front Drive Axle Inner Shaft Bearing
5 - Front Drive Axle Inner Shaft Housing
6 - Front Drive Axle Housing Bracket Bushing
7 - Front Drive Axle Inner Shaft Housing Bolt
8 - Front Differential Carrier Case Bolt
9 - Front Differential Carrier Case Half
10 - Front Differential Bearing Adjuster Lock Pin
11 - Front Differential Bearing Adjuster Nut and Sleeve
12 - Front Differential Case Side Bearing Cup
13 - Front Differential Case Side Bearing
14 - Front Differential Ring Gear Bolt
15 - Front Differential Pinion Gear Shaft
16 - Front Differential Case
17 - Differential Pinion Gear Shaft Lock Bolt
18 - Differential Pinion Gear Thrust Washer
19 - Differential Pinion Gear
20 - Differential Side Gear Thrust Washer
21 - Differential Side Gear
22 - Front Differential Side Gear Spacer
23 - Differential Pinion Gear Thrust Washer
24 - Differential Pinion Gear
25 - Front Differential Side Gear Spacer
26 - Differential Side Gear
27 - Differential Side Gear Thrust Washer
28 - Front Differential Ring Gear
29 - Front Differential Case Side Bearing
30 - Front Differential Side Gear Bearing Cup
31 - Front Differential Case Half Lock Pin
32 - Front Differential Case Half Lock Pin
33 - Front Differential Carrier Case Half
34 - Front Differential Carrier Bushing
35 - Front Differential Drive Pinion Gear
36 - Front Differential Drive Pinion Gear Inner Bearing Shim
37 - Front Differential Drive Pinion Inner Bearing
38 - Front Differential Drive Pinion Inner Bearing Cup
39 - Front Differential Drive Pinion Gear Bearing Spacer
40 - Front Differential Drive Pinion Gear Outer Bearing Cup
41 - Front Differential Drive Pinion Gear Outer Bearing
42 - Front Differential Drive Pinion Bearing Gear Oil Seal
43 - Front Differential Drive Pinion Bearing Gear Yoke
44 - Front Differential Drive Pinion Bearing Gear Yoke Washer
45 - Front Differential Drive Pinion Bearing Gear Yoke Nut
46 - Front Differential Carrier Oil Drain Plug Washer
47 - Front Differential Carrier Oil Drain Plug
48 - Front Differential Carrier Oil Fill Plug Washer
49 - Front Differential Carrier Oil Fill Plug
50 - Front Differential Carrier Hole Plug
51 - Front Differential Bearing Adjuster and O-Ring Seal
52 - Front Differential Bearing Adjuster Nut Lock
53 - Bolt
54 - Front Drive Axle Inner Shaft Bearing
55 - Front Drive Axle Inner Shaft Bearing
56 - Front Drive Axle Inner Shaft Retaining Ring
57 - Front Drive Axle Inner Shaft
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-08-2010, 07:14 PM
guruerror's Avatar
TWR: Did you pull that image from the EPC? If so, what version do you have?
You can find out by clicking Help then About...my build date is 23Jul2007 11:05 124
CNTRY
DTOM
Old 09-08-2010, 10:52 PM
twr's Avatar
twr twr is offline
hi guruerror, it came from Alldata. Its for a 2008 but the diffs are the same but the gear ratio is 410 to 1 in 2007 and down trucks and my 2008 is 373 to 1 do you need a picture of something?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-09-2010, 02:46 PM
guruerror's Avatar
No thanks...I've got a copy of the GM EPC; I'm just always on the look out for an updated version.
What version of AllData are you running? I had a copy of AllData before I snagged the EPC...I can see from your post that the image quality of their diagrams has improved dramatically. The version I had was older and many of the pictures looked almost hand-drawn.
Here's the same diagram from the EPC, they're almost identical:
CNTRY
DTOM
Old 09-09-2010, 04:06 PM
twr's Avatar
twr twr is offline
Hi what is EPC?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 09-09-2010, 04:08 PM
HumminNBoatin''s Avatar
I used a slide hammer to get mine out. However keep in mind if you break that retainer spring you need to split the case to get the broken pieces out. I broke the one on the long shaft when installing my front locker.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 09-09-2010, 04:52 PM
guruerror's Avatar
Hi what is EPC?
Electronic Parts Catalog
It's the Snap-On/Proview software that GM dealers use in their Parts Departments.
CNTRY
DTOM
Old 09-09-2010, 04:59 PM
twr's Avatar
twr twr is offline
Hi is epc a one time buy or a yearly fee?
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
