Old 10-20-2011, 04:43 AM
Boosted Boosted is offline
Boosted is on a distinguished road
Default Updating from 2003 mirror to newer model. Plug issues
I have researched this and can't make any sense of it. I have a 2003 H2 I am putting a newer model passenger mirror on. I have no idea what year it came from. Is there any directions on how to do this? The posts I have found do not seem to apply to my application.
Both mirrors have 11 wires. Matching colors to colors is not going to work on more than one wire.
Old mirror black plug = 4 wires
Old mirror blue plug = 7 wires
New mirror black plug = 5 wires
New mirror white plug = 6 wires
Any help is appreciated.
Old 10-20-2011, 11:37 AM
ffl ffl is offline
ffl is on a distinguished road
Default Re: Updating from 2003 mirror to newer model. Plug issues
i think you got a mirror for a 2007 h2 and up.
these connectors do not fit to the earlier ones. you should have a mirror for 2003-2006 i think. the connector colours should be black and blue, not black and white (2007 and up).
Old 10-20-2011, 01:29 PM
I have seen people say they made the mirror/plug work. That is what I am hoping to do.
Old 10-20-2011, 02:18 PM
ffl ffl is offline
i think this might work, but you probably have to change the location of the wires in the plug (or cut and solder them). i don't know if the white plug fits the blue one nor do i know how the wires have to be arranged.
Old 10-20-2011, 08:29 PM
Easy Ed Easy Ed is offline
Couple old post that may help.
http://www.elcovaforums.com/forums/s...ad.php?t=32940
http://www.elcovaforums.com/forums/s...t=35461&page=2
Hope it does ya some good, Ed
Old 10-20-2011, 09:10 PM
I have seen those two posts already. No help...Thanks though.
Old 10-20-2011, 09:45 PM
How about a wiring diagram from a 2003 service manual ?
All the help I can offer, good luck, Ed
Old 10-20-2011, 09:51 PM
Any idea of how i can get the schematics for my mystery mirror?
Old 10-20-2011, 09:57 PM
Tracy (twr) has a 2008 SUV, I think he can produce one for that model year to see if it matches your mystery mirror.
Here is Tracy's info, might try to PM him.
http://www.elcovaforums.com/forums/m...poster&t=41968
Old 10-22-2011, 06:51 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
1998 Chev Z71
2007 Chev Trailblazer SS
Old 10-25-2011, 05:30 PM
Do you have the diagram for the passenger side?
Old 10-25-2011, 07:00 PM
HUMTECH's Avatar
1998 Chev Z71
Old 10-27-2011, 02:52 PM
I need the diagrams for these plugs. This is a newer style mirror for a H2. No idea what year.
Old 10-27-2011, 09:38 PM
I have no idea what ya got but am hoping HUMTECH will check back in and see the pics and help ya figure out which plugs ya have.
Good luck, Ed
Old 10-28-2011, 01:13 AM
HUMTECH's Avatar
Heres the white one
Connector Part Information
? Harness Type: OSRVM - Driver
? OEM Connector: 15127040
? Service Connector: 15127040
? Description: 10-Way F 0.64 Series (WH)
Terminal Part Information
? Terminated Lead: Service by Component ? See Part Catalog
? Release Tool: Pending
? Diagnostic Test Probe: Pending
? Terminal/Tray: Not Available
? Core/Insulation Crimp: Not Available
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2469802&from=ns&from=sm#N6566 5">Door Lock/Window Switch ? Driver X7
Pin
Wire
Circuit
Function
1
0.35 BN
6802
Driver Folding Mirror Motor Retract Control
2
0.35 GY
6803
Driver Folding Mirror Motor Extend Control
3
Not Used
4
0.35 D-BU
784
Driver Mirror Vertical Position Sensor Signal
5
0.35 RD
786
Driver Mirror Horizontal Position Sensor Signal
6
Not Used
7
0.35 D-GN
672
5-Volt Reference
8?9
Not Used
10
0.35 PU
673
Low Reference
1998 Chev Z71
Old 10-28-2011, 01:18 AM
HUMTECH's Avatar
And the black one
? Harness Type: OSRVM - Passenger
? OEM Connector: 15127042
? Service Connector: 15127042
? Description: 10-Way F 0.64 YESC Kaizen Series (BK)
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=2469806&from=ns&from=sm#N6566 5">Door Lock/Window Switch ? Passenger X3
Pin
Wire
Circuit
Function
1
0.35 PU/WH
6162
Outside Right Mirror Vertical Position Control
2
0.35 RD/WH
6161
Outside Right Mirror Horizontal Position Control
3
0.8 BK
628
Low Reference
4?5
Not Used
6
0.35 WH
7196
Outside Right Mirror Drive Motor Common
7
0.8 BK
2267
Mirror Heating Element Control
8?10
Not Used
1998 Chev Z71
Old 10-28-2011, 05:09 AM
I have not had a chance to sit down and mess with this. I see the top picture says driver. I am assuming the wiring is the same driver/passenger?
Old 10-28-2011, 08:10 PM
Here is the new mirror wires tied into the old plug (no soldering). I am able to fold the mirrors in and out, but I am not able to adjust the new mirror up, down, left or right. Can anyone confirm if my configuration is correct or not? I purchase the mirror on fleabay and it should be working. At this poing I am wondering if the up, down, left, right motor is broken. Can that be replaced if it is broken?
Any help is greatly appreciated!
Old 10-28-2011, 09:47 PM
Mirror folds in fine. I can hear the up, down, left, right motor turning, but the mirror does not move. I assume there is a gear or something that is messed up? Any way I can fix that? Any ideas how to take the cover off so I can check it out?
Old 11-11-2011, 02:00 PM
tsdrummerboy's Avatar
tsdrummerboy tsdrummerboy is offline
tsdrummerboy is on a distinguished road
I have an 03 and I found mirrors from an 05 that had the black and blue plug ends,just like the 03.I tried one from an 08 w/ a blk and white end and won`t work.I tried spliceing,dicing and praying and nothing worked.So I sent that mirror back and shopped around till I found an 05...plugged right in with out any trouble and is still working great to this day.
