09-30-2005, 05:43 AM
Anyone have problem with DIC saying "turn signal on" after doing this mod? Mine comes on when I did this mod. I have the DRL come on with low headlights.
2005 H2 SUV (Yellow)
2003 Vert Supercharged
09-30-2005, 08:41 PM
nope. Checked the jumper settings?
'03 H2
10-09-2005, 06:52 PM
I decided to do this to my truck the other night and, while I had the soldering iron out, I made a total of three jumper wires with diodes. I obviously only need one of these so the first two people to PM me with their address will each get one. The diodes are soldered to black wire on the 'feed' side (the side that goes to the parking light, low or high-beam relay) and red on the side that goes to the DRL relay. They're heat-shrinked and long enough to allow you to attach to any of the three aforementioned 'feed' relays...just cut to size and be on your way.
10-10-2005, 01:37 PM
I think I am going to have my DRLs wired to a switch so I can trun them on at any time.
For those interested, I have seen the DRL bulbs available in yellow so they can be used as fog lamps.
10-24-2005, 09:41 AM
Alright, I have just read the last 5 pages of updates and I am more confussed than when I started. If someone can summerize what I need to do I would really appreciate it. I have an 06 that I just want to add the DRL to the auto function for use with the Headlights. During the day I would like them to opperate as they do normally without any additional lights or markers on. Lastly can anyone tell me what they would reccomend if I want to upgrade to a brighter DRL and Headlamp without the cost of the HID's. What DRL bulb would compliment the Silverstar Headlamps?
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
10-24-2005, 08:29 PM
CAUTION CAUTION CAUTION, I tried the jumber today on a 06 H2 exactley as outlined with the jumper and the diode. Worked for about 30 seconds and then it started spitting and sputtering and stopped running. Tried restarting it several times had to have it towed into Hummer they said that it has fried the ECM. This vehicle only has 380 miles on it. They will not warranty it, I ll know tommorrow what it is going to cost. Has anyone had anything like this happen. HELP!!!
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
10-24-2005, 11:15 PM
Bummer about the fried electro-BBQ. Methinks you did not do it correctly, unless AMGen redid the box. Even then, the schematic should have shown you the correct slots.
Want-08 Viper, 06 M5
10-24-2005, 11:44 PM
Does anyone know if the Fuse box did indeed change from 05 to 06?
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
10-24-2005, 11:51 PM
No idea on the fuse box, sorry to hear about that though. I just tried this mod, and it worked successfully. The one wire keeps the DRL's on at all times, even with High beams. Now, I just have to get some serious DRL bulbs and get rid of the sissy stock ones!
~2005 Stealth Gray H2 SUV.
10-25-2005, 12:06 PM
Originally posted by xAlt:
I did this mod in Jan 03 and it's still working.
I did this mod in Jan 03 and eventually needed a new fuse panel.
10-25-2005, 11:05 PM
Man, have you found anything out? Did you mistakenly place the wire incorrectly? I was going to do this (even made up the diode) but not until I find out what happened.
Keep us updated please.
Mark
PS. My bodyshop does alot of business with the local Hummer dealership. I don't know if it'll help but get your price and I'll see it I can get it for your cheaper. Right off the bat my shop gets 25% off list, if I have a problem child, they usually help us.
PM me if I can help.
Mark
10-26-2005, 12:02 AM
Originally posted by OrangeCrush:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by DeBest:
Mark
Mark </div></BLOCKQUOTE>
Mark if you can get me a price on the ECM I would appreciate it. I told the dealership that I will tell them by Friday what I am going to do. I still can not believe there isn't some way they can warranty that part. If you can PM me as soon as possible I would be very appreciative
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
10-26-2005, 12:09 AM
PM sent.
10-26-2005, 01:35 AM
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
10-26-2005, 04:15 PM
Not sure if this helps but here it is.
The PCM for an '06 at my cost is 318.00
If I can help you, let me know.... it lists for 585.00
Mark
10-26-2005, 07:26 PM
Mark,
Thank you for the price on the ECM, can you find out how many hours the book calls for the replacement of the modual I am trying to get a total price. This way I will be much better prepared when I talk to the dealer on Thursday.
Thanks Again!!!
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
10-26-2005, 08:31 PM
Ok, I haven't actually replaced the pcm in an H2 before...but it's not that hard is it? I've replaced pcm's on other vehicles and it was a matter of disconnecting cables, and swapping it out....
'03 H2
10-26-2005, 10:28 PM
I'll check tomorrow but I honestly can't see it taking very long. Most ecm's only take a few minutes to replace. Sometimes you may have to remove some bracketry/battery/brace to get to it but I couldn't fathom it costing more than an hours labor.
However, I will check tomorrow.
Mark
10-27-2005, 01:06 AM
I was told that the ECM on a 06 H2 is up under the dash behind the instument panel and that it is quite involved to get to it. I was told that the whole dash practically has to come off to get to it. I hope someone can tell me exactly where it is and how many hours the book calls for to replace it.
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
