01-27-2006, 12:35 PM
Ken, mine's better since it doesn't have any red on it. It's all black and sliver/pewter. Plus from the sounds of it, I got mine done faster than you...I used a knife.
'03 pewter base H2
01-27-2006, 04:28 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TootsSUT:
... then run wire in to the rubber seal along the back door, bring up to roof and attach to antenna(s). </div></BLOCKQUOTE>
Does the door close on the coax? </div></BLOCKQUOTE>
NO there is an odd little gap  - mine is run the same way. It's clean, easy, and works! I'll post some pics in a little bit...
Sean
01-27-2006, 05:26 PM
Ken - FWIW, this is how I ran mine. Of course, through the marker light would be a bit more professional and be totally invisible, but I agree - it's a PITA!!!
Sean
01-27-2006, 05:54 PM
Hmm, that looks like
01-30-2006, 06:11 PM
Hey Ken,
I have the same set-up with duel mounted 4 ft. sticks, easy to install, and drilled no holes, mounted the duels to the tail light guards, and looks sweet, works great!...good luck with yours!<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by KenP:
Hey, here's a pic of our latest mod. It was super difficult getting the packaging off, but I think it looks real cool on the work bench. What do you all think?
(This post especially for OC  ) </div></BLOCKQUOTE>
01-30-2006, 06:15 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
Sean </div></BLOCKQUOTE>
Bondage,
Wouldn't gorilla glue look a little foamy brown??? Thats the way it always looks when I use it?
If you think it needs more securing I think it'd look better with a well cut strip of roofing rubber.
'03 pewter base H2
01-30-2006, 09:06 PM
 </div></BLOCKQUOTE>
x2 </div></BLOCKQUOTE>x3
My coax just runs out the top of the door over the black trim. No need to try to stuff if down in a crack.
01-30-2006, 09:10 PM
Might as well put a WallMart $14 magmount up there and run the coax through a gap in the window  </div></BLOCKQUOTE>Well mine is a $80 Wilson 1000 magmount and I thought about the window but it would bug me when I opened the door.
01-30-2006, 09:21 PM
any pics of the install process/route or the finished install?
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by La.Swamp Lobster:
Hey Ken,
(This post especially for OC  ) </div></BLOCKQUOTE> </div></BLOCKQUOTE>
01-30-2006, 10:35 PM
Ha. Tough install Ken  . I wish I were in your shoes right now. I'm installing GPS, here's some pics. Ever wonder whats under the dog house of the H1?
1997.5 Black Slantback
The Sole Remaining God Father
-007=
01-30-2006, 10:37 PM
Alot of ****...
-007=
01-30-2006, 10:40 PM
Here's a pic of my CB, as far as I'm concerned it doesnt get much better. The switches above are for my lights and DVD system.
-007=
01-30-2006, 10:41 PM
Harky, I love that interior. Did you do that yourself?
That's a lot of wires. It looks like your dash threw up. No wonder you little monkeys take so long doing stuff.
01-30-2006, 10:49 PM
Here is how i mounted my antenna. i use a 4' firestix o-ground plane.........i can send and recieve up to about 25 miles.......
03 H2- polished stainless brush gaurds, front and rear. front and rooftop lighting, hard cargo carrier....
No. Most of the work was done by the previous owner. I cant afford to add all that stuff, the wood trim alone is about 2700.00. I've added sattelite radio and now the GPS to the inside, there's really not much that can be done to the interior, its already so modified. I dont know who your wheeling with, but it doesnt take that long. Thats only about 45 minutes of work for me.  Now, that alternator problem is another story...
-007=
01-30-2006, 10:59 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fubar:
Hey Ken,
(This post especially for OC  ) </div></BLOCKQUOTE> </div></BLOCKQUOTE> </div></BLOCKQUOTE>Here you are Fubar:
http://elcova.com/groupee/forums/a/t...1/m/7411047451
Carey, what's that little green wire for?
01-30-2006, 11:41 PM
KenP, Thanks.
