Old 01-26-2006, 07:42 PM
Hey, here's a pic of our latest mod. It was super difficult getting the packaging off, but I think it looks real cool on the work bench. What do you all think?
(This post especially for OC )
Old 01-26-2006, 07:53 PM
Spike Spike is offline
Ken,
I actually almost bought that one. That is the cobra right? I wound up buying a cobra handheld so I wouldn't have to deal with an antenna. If there is any "drilling" involved, make sure you measure at least twice!! I'd like to see some pictures of the unit and the antenna mount after it is installed.
Old 01-26-2006, 08:18 PM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
Oh goody! Maybe mine will come today to!! If it does, I'll post pics!
Old 01-26-2006, 09:19 PM
I have the same setup, and you can install everything without drilling if you use enough duct tape and cable ties </div></BLOCKQUOTE>
Ditto. Have that one too. No drilling required.
Old 01-26-2006, 09:26 PM
Nice work Ken. You should take a breather and smoke a cigarette before attempting phase two </div></BLOCKQUOTE>
ps-
WRONG SECTION
Old 01-26-2006, 11:10 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Make sure to post some pics once you get it installed.
Old 01-27-2006, 12:30 AM
WORKIN WORKIN is offline
WORKIN is off the scale
(This post especially for OC ) </div></BLOCKQUOTE>
nice kit. you may want to consider loosing the spring mount for that firestick. they are so thick the wind will blow them at a back angle, causing you to loose valuable distance in how far you can send and recieve.....
03 H2- polished stainless brush gaurds, front and rear. front and rooftop lighting, hard cargo carrier....
Old 01-27-2006, 03:50 AM
DAMN!!! I just got home and realized I have to turn the page. CRAP and thanks alot!!!
Ok, I think I'll have to actually put the CB in the truck to make it work. Crapdamn...
As to the spring, well hell, everything else is screwed up now.
I'll never get this junk to work...
Old 01-27-2006, 04:14 AM
rodster rodster is offline
rodster is off the scale
Just remember Ken, in spite of what some may say, you really do need to tear out the center console and dash to install two wires and a coax.
\'05 SUT
Old 01-27-2006, 04:16 AM
TootsSUT TootsSUT is offline
TootsSUT is off the scale
That's exactly what I got and it is fabulous!!!
Ginger
Old 01-27-2006, 04:24 AM
Just remember Ken, in spite of what some may say, you really do need to tear out the center console and dash to install two wires and a coax. </div></BLOCKQUOTE>
I installed mine with out creating any new screw marks. Definitely install under the center console but also you can put the cable under the seat then place it under the easily removed plastic piece at the bottom of the rear door entry (lots of space), then run wire in to the rubber seal along the back door, bring up to roof and attach to antenna(s). Works fabulously and is very clean.
The hand held is placed to the right of the steering wheel where the original screw is in the dash!!j Haha!!
I'll get pics if you want them!!
Ginger
Old 01-27-2006, 04:51 AM
I hate wiring through the front marker lights.
Old 01-27-2006, 04:56 AM
I never touched the front market lights but I'm not certain where your antennas are going to be? Best place for them, from what I've been told, are in the rear of the vehicle. Could be wrong though!
You'll see with the pics.
Ginger
Old 01-27-2006, 05:01 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TootsSUT:
... then run wire in to the rubber seal along the back door, bring up to roof and attach to antenna(s). </div></BLOCKQUOTE>
Does the door close on the coax?
\'05 SUT
Old 01-27-2006, 05:34 AM
ps-
WRONG SECTION
</div></BLOCKQUOTE>
Old 01-27-2006, 05:37 AM
I hate wiring through the front marker lights. </div></BLOCKQUOTE>
It's easy. Make sure to fill it up with silicone sealant.
BTW, I've got the same set up. I think you might have an issue with the antenna mount, though.
Old 01-27-2006, 11:21 AM
BTW, I've got the same set up. I think you might have an issue with the antenna mount, though. </div></BLOCKQUOTE>Me too. May have to go a different route.
