Old 01-27-2006, 02:38 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by walc:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Sewie:
You lose about 1" of clearance.... </div></BLOCKQUOTE>
Now, I have to think, again.
Is it worth losing 1" of clearance, when I only have 32" tires?
KenP's idea may be a better alternative; specifically:
"BTW, this is what I'm thinking about trying:
Taking some 1/4" plate and weld it to the stock UCP. Then cut some large holes for ventilation. Cheap and it should last a while." </div></BLOCKQUOTE>
Don't forget, if the skid plate is keeping the big rocks away from your undercarriage, it's also keeping lots of mud away from the pressure washer and out of site. You'd be surprised how much mud can accumilate ontop on things under there! It will pack up under there and eventually cause lots of heat build up! If you do make the skid plates, make them easily removable, maybe a rivets, and not welded.
IMO
Ric-H0
www.meatspin.com
