Re: HOW LOW CAN YOU GO???????
matt
cincy oh
I did this on my Cherokee, just ran the lines up to the firewall in front and the gas filler cap in back. You could also just get a long piece, loop it over & over, then put in a 1-way valve - as long as you don't sit still too long in the water, the loops will prevent water from coming into the difs (sorta like a P-trap).
My vehicle may occasionally be attracted to small puddles
'06 H3 Adventure (9/2005-1/2013)
After any deep water fording (deeper than centerline of axles) it wouldn't hurt to check fluid in diffs, trans and t-case for water.
If the oil looks green and foamy you have got water in there.
Drain and flush and drive and drain and flush again to get all the water out.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Thread Tools
Search this Thread
