Old 07-16-2006, 06:51 PM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
Default Re: Stabilitrak Chime Warning (even when off)
Originally Posted by f5fstop
Your DIC is part of the Serial Data Bus (purple wire(s)), removing this wire will set codes up the rear end and drive you nuts with the service engine light on. So, it is best to leave your DIC alone.
I want to be able to disable the chime only when the running lights are on and the truck is off (sitting around w/the stud lights on) or when the key is in the ignition or ACC when the door is open. I like the chimes the rest of the time. Is there a way to wire a little micro switch inline with a wire somewhere to shut off the chimes temporarily?
Old 07-16-2006, 08:15 PM
Not that I'm aware of.
