Old 08-23-2006, 02:59 PM
Groundpounder Groundpounder is offline
Groundpounder is on a distinguished road
Default Flashing brake light??
Does anyone have information about a set up that allows the brake light to flash, when the brake is applied, then go to steady red? I know they make one for a motorcycle, however, I have not been able to find one for a vehicle.
I might be able to hook up a set of red strobes to the brake light but they would be flashing the entire time the brake is engaged. I plan on getting a set of red strobes anyway. Being a police officer, I will work traffic for a wreck if I am the first one there and I do not want someone to rear-end my H3.
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate. Semper Fi
Old 08-23-2006, 03:12 PM
ree's Avatar
ree ree is offline
Default Re: Flashing brake light??
Confused. What's the benefit over using 4-ways/hazards?
'03 pewter base H2
Old 08-23-2006, 03:27 PM
I am looking for better recognition when the brakes are engaged. That is why the motorcycle rear lights were developed, to inform the nut behind you that the person in front is going to stop. Sort of a wake up call. They flash five times then go steady red. The emergency flashers are OK, however, they require you to push another button. Not good for stopping/braking.
As for emergency flashers to direct traffic - so..so. The strobe gets someone's attention better.
Old 08-23-2006, 03:37 PM
ree's Avatar
ree ree is offline
Thanks for the description. Sounds a little like municipal busses whose brakelights flash if the speed of the bus decreases.
'03 pewter base H2
Old 08-23-2006, 04:30 PM
marin8703's Avatar
check out http://www.strobesnmore.com/ , they have everything on the market related to this kind of stuff, thats where i get all i need.
I know what you are looking for, and i looked around but couldnt find one. the closest thing would be Flashback Taillight Flasher. it might not be good for you because its a hard wire product and it will do it all the time, but i guess you can put a switch on it. this is what it does:
The Flashback alternates the brake lights against the back-up lights at 2.4 flashes per seconds. It also has an additional output for deck lights.
Again, i know its not what you are looking for but check it out, it will make you visible no doubt.
oh a buddy just told me to check out http://www.lshlights.net/ and http://www.galls.com/ and http://www.chiefsupply.com/Vehicle_Equipment .
If none of these guys have it you probly wont find it anywhere.
Im betting its not that difficult to make, if you know someone with electronic/electrical experiene, maybe they can make some kinda flasher for you.
If you find please post, im interested in that too!
just found this http://www.signaldynamics.com/products/Modules/xp.asp . Its made for motorcycles, but it says something about cars too. I think it can be fitted on a car also!
Old 08-23-2006, 05:35 PM
I have always used them on Vettes, since I wanted to make sure everyone back off. Vettes generally stop better than most vehicles. With the H3, I say to the tailgaters, "come on under the back end and say hello to my rear axle...don't forget leave your head at the bumper."
Ecklers and other places sell them for Corvettes, and the systems are the same. However, the connector to the Corvette CHMSL is different than the H3. I don't see why you could not purchase one, and wire it in the old fashioned way with butt end connectors.
Basically, the units are designed to plug in-line with the wiring harness to the CHMSL (center high mounted stop lamp).
In fact, it looks like the one Eckers sells is for splicing in, versus connecting.
http://www.ecklers.com/product.asp?pf_id=40726&dept_id=1384&mscssid=B83NL NPRLD759JCDR12XC870VFQB3M62
http://www.autoelectronicupgrades.co...ll/install.htm
http://www.webelectricproducts.com/products.htm
Old 08-27-2006, 01:12 PM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
I have the WebElectric unit installed on my Vette. Works great. The thing I like about it over the others is the fact it does not continue to flash if you are sitting in traffic with the brake on, which can be annoying to someone behind you. It will only repeat the 3 flashes if 15 or more seconds have passed since the last brake.
The also make a Generic one which will fit any vehicle called the
BLP-1 Generic Brake Light Pulser Module
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
Old 08-28-2006, 03:10 AM
H2Finally's Avatar
AutoTruckToys sells em for the Hummer for just $21.95
I've ordered, but have not received them.
Can BLING Get You Home?
Old 08-29-2006, 10:07 PM
JWSchmidt3 JWSchmidt3 is offline
JWSchmidt3 is an unknown quantity at this point
They make these for Corvettes, I would think they would exist for most brake wiring applications. It's just a pigtail that intercepts the brake signal then outputs a programmable pulse signal. For Corvette people, some think it's a piece of mind, being so low to the ground, keeping people from running up their ass.
J.W.
2006 yellow H3 - Pro Comp Xtreme package
4" lift, 35's, Lux, etc.
2004 yellow Corvette Z06
2002 black LPE blown TigerShark Z06
http://public.fotki.com/JWSchmidt3/
Old 08-29-2006, 10:10 PM
I obviously didn't read the previous posts. Guess you have your answer.
J.W.
