Old 09-25-2006, 10:47 PM
socal-h3 socal-h3 is offline
socal-h3 is on a distinguished road
Default Re: Exhaust,intake,throttle body spacer
how are you getting "lower" rpms with small power gains? i dont think that adding power to the engine has any affect on your cruising rpms. that has to do with the gearing in the tranny and hp does not change gearing. am i over looking something here?
Old 09-27-2006, 03:42 AM
Hunner's Avatar
Hunner Hunner is offline
Well more torque is what I understand to push you farther on the same rpms. It was the same on my truck.
Old 09-27-2006, 04:14 AM
Hunner's Avatar
Ok got the mock up or protype today. Just wanted to post that an AirMax intake for a Colorado truck will not work on our H3 because of the air conditioner hose over there will not let it line up. So they made me one. They pulled it off to make a cad drawing and have one laser cut and powder coated. Im going back Wed to put the prototype on and drive it for a few days to see if all works well.
The throttle body spacer by them works on the H3 and the stock air will all go back on. The True Flow would work as well.
SOPD will have to do for comparison to a Colorado because the dyno is not for four wheel drive. I guess GM either has one or matamatically figured HP and torque.
For now we used the bellows coupler from the stock setup. We increased the tube size over the True Flow pipe from 3" to 3 1/2" same size all the way from throttle body to filter. We were making this up as we went along and decided with the full volume pipe we could leave the bellows to allow for engine torque and movement especially in low range and uneven terrain. Just a thought. I know it does not look as smoothe but they wanted to try this for now. More later, I have started a mpg log but I think the first tank is going to be poor, I can not keep from WOT to hear and feel it! Im still running no Muffler and straight pipe where it was but left the cat, oval pipe and resonator for now.
I still have mixed feelings about the open filter off-road but after all the engine is going to suck in whats out there. I now have the options for either. Water is my main concern about the wide open exposed filter. I guess in monsoon season I can swap.
Old 09-27-2006, 04:44 AM
Hunner's Avatar
Here is a close up of the protoype. They glued in the spiral flow section. Im getting dizzy just thinking about all this. Its a section of plastic tubing, very thin that has a spiral twist raised ridge for about four inches. Whatever.........
Old 09-27-2006, 04:48 AM
Hunner's Avatar
Gang machining on the CNC
Old 09-27-2006, 04:49 AM
Hunner's Avatar
The mother load!
Old 09-27-2006, 09:59 PM
Did you match the ID of the stock air tube where the MAF is located?
Old 09-28-2006, 04:39 PM
Hunner's Avatar
Actually no. I did ask about that. That is about 2 1/2 right at the sensor on the stock air box and opens up to 3 1/4 on the short stub that connects to the accordian type stock hose. Mine is a 3 1/2 piece of pipe and slightly less id. I will check that for info. Just the thickness of pipe less. If I understand it right it wants to meter 5% air but Im not sure about how all that computes.
We road tested and everything checked out. Then about an hour later I got the check engine light. They took that one off and made a new one moving the mounting point closer to the engine end. I have been about 100 miles since then and no light. It is a protoype. Im surprised it has worked so well. They wanted to make sure I had enough flex between ridgid mount shield and engine. I think that sacrificed the smooth transiton I wanted. We are not thru yet.
The True Flow design pipe is really a great idea and could be made easily. I think I found a source for the silicone boots. They have some generic black ones where I did all this for $15 each. Without opening the stock box you dont gain more air. That setup would work well if you put on the top for off-road nasty conditions. It still improves performance with the lid on but not as much. I let the air down on my tires off-road so I could easily swap intakes. For casual off-road it would probably be ok either way. I go to a park, SuperLift here in Arkansas on weekends and drive alot so I would like it covered for that.
Any input is appreciated. More experimenting is needed.
