Old 10-16-2006, 01:35 PM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
Default Re: Couple of new toys
Nice toys love those vavle stem cover good idea.
Old 10-16-2006, 02:56 PM
Crash ?'s Avatar
Crash ? Crash ? is offline
I've got that Midland.. If you're going to use it with the car adapter you're going to have to mount an external antenna.. You can' power it from a cig plug and use the rubber BNC antenna..
I mounted a Firestik Firefly 4ft on the roof with a flip over mount and am keying an SWR of 1.1 (ch1) - 1.4 (ch40).. Range isn't but maybe 3 miles talking in town, but a 100 watt linear could be hooked in for $100 or so and stretch that on out to 10-15 miles out in the open..
I think Sewie has pics on his website of this antenna setup that he used on a Cobra handheld...
Rob
I went with the Midland because it can be used as a portable radio to walk around with if needed..
Old 10-16-2006, 04:38 PM
I have a six foot red/white/blue firestick from my Jeep that I could use. Has me thinking.....
Old 10-16-2006, 04:56 PM
Wisha Haddan H3's Avatar
Weird, the manual says you can use the attached antenna (with limited range), but I was going to look into an external mount anyway.
Old 11-15-2006, 11:07 PM
SR1355's Avatar
SR1355 SR1355 is offline
So how do you like the Staun Tire Deflators, I'm thinging off getting a set and adding them to "What do you carry in your cargo door jack compartment".
Paul M
SR1355
Old 11-15-2006, 11:42 PM
Haven't used the deflators yet, but they look solid. One of these days I'll have to try them out. They're factory pre-set to 18 psi, but you're supposed to double-check the pressure.
But the NATO valve caps are awesome. Got really cold here recently and I had to top off my tires. It was nice not taking the gloves off to handle the caps, dropping them when my fingers go numb and fishing them out of the snow. Definitely worth the $10. The threads seat well too ... high quality.
Old 11-15-2006, 11:57 PM
SR1355's Avatar
Thanks, I think I'll pick up both.
Paul M
SR1355
Old 11-16-2006, 12:37 AM
They definitely make it easier/quicker to air down. But you should check the setting on them fairly often as they tend to "adjust" themselves pretty easily.
Old 11-16-2006, 12:53 AM
SR1355's Avatar
Thanks for the advice, I sure hate to air down to far and lose a bead.
Paul M
SR1355
Old 11-16-2006, 04:01 AM
westhillsat's Avatar
Neo put black marker lines on his to tell if they turn from where he wanted them set
I still need to do that
Old 11-16-2006, 01:24 AM
You can use it with the stock (integrated antenae) just watch the squelch or it will fail. Range is about 3 miles line of sight.
Old 11-16-2006, 04:31 AM
Crash ?'s Avatar
hhmmm.. Makes me wonder why mine won't.. I wound the squelch all the way up and down and got nothing out of it.. May have to do some expirimenting this weekend and see what's up with the thing...
Rob
Old 11-16-2006, 04:01 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
I have that CB. It works GREAT!! I had a local CB shop connect a 4' Wilson fiberglass anenna to the rear bumber. I ran the cable up throught the truck and under the drivers seat and into the center console. Attached the wire to the external adapter on the CB and plugged the power in to the dash.
i recently used it on a trip with my club to the badlands. everone was asking me about my radio and could not believe that my simple little set up that tucks away in my center console sounded better than anyone! I was very pleased and the total cost of my set up was just under $150. I also bought my CB at Wal Mart.
I highly reccomend this.
____________________________
