Old 10-16-2006, 07:59 PM
H3HUMMER's Avatar
H3HUMMER H3HUMMER is offline
H3HUMMER is on a distinguished road
Default Re: Which OPTIMA battery to use?
The yellow one is the best
Old 10-16-2006, 08:01 PM
H3HUMMER's Avatar
http://www.optimabatteries.com/publi...utomotive.html
Old 10-18-2006, 10:12 PM
Please accept our apologies for the delayed response.
We do not have information for the H3 as of yet, although if it takes the same battery as the H2, the correct battery would be the 34/78 red top or D34/78 in the yellow top.
Please feel free to contact customer service at the number below if you have any other questions. Thank you for your interest and support of Optima Batteries.
Optima Batteries
Customer Service
1.800.292.4359
Old 10-20-2006, 11:50 PM
Disregard the previous post.
Those batteries are 10" long. I tried another 10" battery this evening that the base service station had; however, it wouldn't fit (at least not without some cutting). I am trying to find a nearby Optima dealer with some of the other models available that are just over 9" long.
I am getting the sh*ts of my battery leaving me standing there with my jumper cables.
Old 10-21-2006, 03:57 PM
Originally Posted by DesertDan
I put in a Red Top.
It came with a different clamp/clip that fits at the bottom of the battery. The nylon strap is too loose with the optima and the plastic cover needs to be trimmed to make room for the sight change in the terminal locations.
DesertDan would you happen to know the Red Top part number? Can you describe or show a picture of the clamp/clip you used? Can you describe or show a picture of the mod you made to the plastic cover?
Trying to find a battery for my H3 overseas is turning out to be a pain. I can get one at the HUMMER dealer, but it is $368 and a 6-hour roundtrip to collect it. They cannot ship it to me as they don't have a courier to transport acid filled batteries. (I bet this same battery is $100 back in the States.)
I can get a gel battery like the Optima ($40-80 cheaper) shipped, but who really wants to take the Dremel drill to their new car to make it fit?
  • Who has bought a replacement ACDelco P/N 86-7YR? Cost?
  • Who has had their ACDeleco battery replaced with another free by their dealer?
  • Who has replaced their battery with another brand like the Optima? What was the part number?
Old 10-22-2006, 11:18 AM
I pulled out my POS dead ACDelco (P/N 86-7YR) battery. It is making a nice paper weight in my garage. I also have a paper weight in the driveway called a H3.
I will trade you some battery specs below for pictures of your gel cell battery installed in your battery tray, and a description or pictures of your battery tray mods:
690CCA and 50Ah
L: 9" *
* The battery box has plastic tabs on each end. If you remove the 3 tabs on one end, then you'd get about another 1/2". If you removed a wire fastener and 3 tabs on the other end, you'd get another 1/2". A 10" L battery would be tight.
W: 6-3/4 - 7" **
** The base of the battery is 7" but then it tapers in slightly to 6-3/4". I think if it was a straight 7", you might have an issue with the metal bracket that holds the nylon strap.
H: 8-1/4" ***
*** This includes 1" for the posts.
The battery box lid has some extra big holes for the terminals. On the width side, they are centered between 5" + 1-3/4". On the length side, they are like 0.8" + 7.3" + 0.8". It will be hard to understand, so it is probably easier for you to measure this one yourself.
Optima 25, 35, and 75/25
720CCA and 44Ah
L: 9.313”
W: 6.813”
H: 7.625”
Optima 34 and 34/78
800CCA and 50Ah
L: 10”
W: 6.875”
H: 7.813”
Old 10-22-2006, 05:39 PM
Angry Who is using a different battery? Pictures? Model?
A funny joke for you
What do you get when you have a POS one of these?
A (brand-new) driveway paper weight !!!
