Old 10-16-2006, 09:52 PM
Default Re: difficulty disengaging 4hi lock
also check that buttons are not sticking in the in position my hi loc button was sticking in the in position and would not let other buttons engage . i was able to grip sides of button with finger nails and pull out then other buttons were fine . took to dealer and they fixed the sticky button
Old 10-16-2006, 10:34 PM
Try working it and listening in a quiet area. You should hear the transfer case switching gears. If you dont its a contact problem on your console.
Old 10-16-2006, 10:46 PM
My entire switch panel was replace after my first Rubicon trip.....
Old 10-16-2006, 11:27 PM
Desert Dan's Avatar
Maybe this push button 4x4 and low range aint what it is cracked up to be
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-16-2006, 11:38 PM
sltbluh3's Avatar
sltbluh3 sltbluh3 is offline
sltbluh3 is off the scale
yep I pressed the onstar button and after 15 minutes they had me backup turning right for about 60 ft and bingo you come out of 4-HI weird but it worked... hope you can turn right going backwards when it locks.. its also in the manual so they say never looked...
Slate Blue, Luxury Package, Chrome Package, Chrome Rims,XM,Chrome step tubes,trailer package,Air Raid throttle body,SMA cold air induction,GHL Exhaust
