Old 01-27-2007, 11:01 PM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
Default Re: Rear Brake/Axle Groan...
Could it really be that your lube took care of your ongoing problem. You have to wonder why the dealer couldn't have done that?! Your dealer must have chamfered your rear pads the first time you took it in with the problem. The dealer who did that to mine (which I think fixed my problem) told me he did it (chamfer) because it would help keep the groan/grind away since I brake so much on windy, hilly roads. I don't think he would have explained it to me if my pads were already cut that way.
Anyways ... fourfourto, for getting to the bottom of your problem and fixing it. I hope you've heard your final groan/grind. If possible, try not to make aggressive stops .. ease into it as best you can. Good luck! Keep us updated if the groan starts up again.
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 01-27-2007, 11:20 PM
fourfourto's Avatar
Just took a ride up to blockbuster and no noise. silence is nice
Either the 3 is messin with me or it solved it ...for now.
I do here a faint "Ill be back"
The real test is if my wife hears it during the week.
F5/ parts guy
Anyone know if the rear pads are cut,they really looked factory cut I dont think I could have had them that even if I tried.
They might be factory replacement,that would explain why the fronts are not done.
Old 01-27-2007, 11:39 PM
Hmmm2's Avatar
LOL .. I know EXACTLY what you mean! I was SURE that I would hear the groan at the next stop! I'd cringe as I rolled to a stop and waited for the sound. I'm only now beginning to accept in my mind that it may be gone. I DID hear it once, but I wasn't driving it .. I was the passenger. No one drives it as well as I do.
Old 02-26-2007, 04:00 PM
fourfourto's Avatar
Update:
After 3,500 mile round trip to FLA there is still no brake noise .
I guess the brake lube did the trick
Dealer had it in at least 4 times and couldnt figure it out
Less then 1/2 hour on the lift with my brother and I and the noise is gone.
Old 03-03-2007, 09:16 PM
Hmmm2's Avatar
Update:
That is GREAT news! Did you only lube the brakes? Did you chamfer new pads, or did you leave the old pads in? Isn't that amazing ... all of that grief and the dealer couldn't find it? I'm glad you're groan-free now! ()
Old 03-03-2007, 10:40 PM
fourfourto's Avatar
All I did was clean and add lube.the replacements were either chamfered or the dealer did it.The fronts were not and they were original.
The noise WAS definatly comming from the back.
I will mention it to the dealer when I go in for another roofrail replacement.
Old 03-04-2007, 09:47 PM
442,
Write a letter to GM's CEO they may help!
