Old 02-01-2007, 01:41 PM
Default Re: 520 PIAA wiring Harness?
Originally Posted by LVDesertSUT
Any of you that have PIAA lights have a better way to wire the harness than the generic instructions included with the kit. I bought a remaining Heavy SMA brushguard with the SMA PIAA Valence with 520 lights. Also any good places to put the relay? Any suggestions for a clean factory install is what I am looking for.
Not sure about "clean factory install" but I mounted the PIAA relays on the frame piece between the battery and the rad.
If you want to use them as Daytime Driving lights, you can wire the switch + from the relay to the + of the existing DD light kit. and wire the line voltage up like the paragraph below.
Otherwise, if you look under the top of the underhood fuse box, there is a post that you can wire your main + for the lights to. This is likely the wire coming from the relay with the loop terminal on the end. It's fused to Stud 1.
You'll then pick a ground somewhere to attach the ground wire. You'll then have to run the switch wires into the cab through the rubber grommet or a hole you make in the firewall. Either way, you'll want to seal it back off when you are done with RTV silicone. With the details from the PIAA and that, you should be able to wire it up.
If not, keep posting up questions, those here should get the details answered.
