Old 02-14-2007, 06:26 PM
Default Re: Who knows how to unfreeze the ground?
Gasoline? Scrotched Earth technique.
I've seen a techinque where they drill holes and use heated pipes.
Old 02-14-2007, 06:27 PM
Hmmmm. I wonder how long that takes. The ground buster guys are coming on Monday.
Old 02-14-2007, 06:35 PM
Try these guys CO.
http://www.groundthawing.com/?gclid=...FRJ_Ywodh1jGuA
$1500 sounds steep. The concept is basic so I couldn't see why you can'r McGyver something together.
Old 02-14-2007, 06:39 PM
Try these guys CO.
Wow, that's about 1/2 the price for 6000 sqft. I only have 400 sqft. But, I have a time contraint here.
Old 02-14-2007, 06:50 PM
ssgharkness020147's Avatar
Just bust out the Oxy/acetylene setup and go to town on the ground.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 02-14-2007, 06:53 PM
Three feet deep?
I'd have nice warm ground, and some cinders that I used to call "home".
Old 02-14-2007, 06:59 PM
Now is where I would post some pics of my S tanks and uber sexy Smith torch with some reassuring words, but its too cold outside for me to take pics. Good luck CO.
-007=
Old 02-14-2007, 07:32 PM
BKLYNH2's Avatar
BKLYNH2 BKLYNH2 is offline
They unfreeze by driving the pipes into the ground, the pipes are then connected to a steam generator and steam is injected into the soil to thaw it. This method is probably not in your budget and is usually done in large excavation projects.
I'd get an auger and drill evenly spaced holes 2 feet deep( For a 20' x 20', maybe 16 holes from a 6" auger bit.)
Fill with rock salt or de-icing pellets, and flood em with hot water from a hose directly from your hot water tank. That will definitely do the trick and the salt will keep the water from freezing up.
There are other ways, but they're not that enviromentally friendly.
