Old 03-03-2008, 07:58 PM
rusty rusty is offline
rusty is off the scale
Default IROK 37x12.50x17
anyone with air suspension run 37x12.50x17 on stock rims and did you do ok/not break air sensor.
they look to be 1/2"+ wider than my bfg mt, which are v. close when aired down.
thx
Old 03-21-2010, 03:03 AM
bmf007 bmf007 is offline
bmf007 is on a distinguished road
Default Re: IROK 37x12.50x17
Just put my new irok 36x13.5x17 no rubbing issues they measure the same as 37x14x17 witch is wierd so you should have no problems.
Old 03-21-2010, 05:16 AM
Hellz Hellz is offline
but do you have the air ride suspension in the back?
you will need to modify the control arm for the airride with 13.5 wide tires
there wont be any issues with 12.5 width tires
Old 03-21-2010, 12:37 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
thx
I have the air suspension and have been running the BFG KM2 37x12.5x17 on a second set of stock rims for over two years with no rubbing and no problems. No lift on the H2.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 03-22-2010, 03:26 AM
Talking Re: IROK 37x12.50x17
Yep have air suspension in the back no problems. Running eagle alloys 17x9 black rims and the irok 36x13.5x17 no problems. I bought the keys for the front and no probelms didnt even put them on. I just went up on my tortion bars a quater of an inch and moved my air ride sensor up an inch to gain some height inthe rear and looks great. Thinking i should of went with a bigger tire but it looks good.
Old 03-22-2010, 02:15 PM
HumminNBoatin''s Avatar
I would do the "Air Sensor Mod" (Search it on this site) just to be sure. If you never go offroad you will be fine. But the first time you flex that suspension with a wider an taller tire you risk a big chance of breaking the sensor arm.
I did this mod and have never had a problem running my Toyo Open Country M/T's. They are 37x13.5x18. Really they are 14.2" wide.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 03-22-2010, 07:40 PM
DuckTruck DuckTruck is offline
DuckTruck is on a distinguished road
I had the air suspension (before I modded it into a "hybrid" system....check my post for more details) and am running 39.5x13.5x17 bias ply IROK's on my stock wheels with no lift on the rear.
Only issue I had was I had to grind or trim a bit of metal off of the support bracket for the air ride sensor arms.....no biggie at all. Other than that.....no probs.
DUCK
2003 H2, Lux & Adv Packages, Cognito 3" front suspension lift, Gobi Stealth Rack w/ Ladder, Navigation, twin Optima battery setup, AirRaid Intake, Granatelli Mass Air Flow Sensor, Flowmaster Big Block II Exhaust, Diablosport Predator Programmer,Cognito Pitman/Idler Arm Kit, Fabtech Tie Rods, Rancho RS 9000 shocks, Warn bumper and 9.5x winch, Warn light bar, PIAA's everywhere (14), everything blacked out, and rollin' on 39.5" Super Swamper IROKs on black powdercoated stock wheels.
Old 03-23-2010, 03:49 AM
What r you running up front any lift? Do you have green keys or torsion keys cranked all the way up?
Old 03-23-2010, 04:06 AM
Big.Z.hummin's Avatar
Big.Z.hummin Big.Z.hummin is offline
Big.Z.hummin is on a distinguished road
DUCK
Any pics of this Beast? It sounds Bada$$!
