Old 07-22-2008, 04:40 AM
H3slate's Avatar
H3slate H3slate is offline
Default Re: Intake Question
Ok, I have had the k&n intake kit on my 06 H3. I have also ran a fram airhog filter in the stock air box. With the k&n intake kit, you get a little more get up and go, especially in the higher rpms. With just the upgraded filter, I have noticed only a little difference if any.
The big thing with the intake kit is, it removes the noise damper box and is a straighter flow through tube. The removal of the noise damper box definitely makes for a louder intake, but also helps with airflow.
The only concern I had with the intake setup was that the filter was not in a completely sealed area. So warmer air could get in the intake and possibly dirt and debris.
