Old 01-09-2009, 08:47 PM
Desert Dan's Avatar
Default Re: Changing to 2wd
After having full time 4WD for while I would prefer to have a manual t-case that I could switch to 2WD when I wanted to and have manual control over low range rather than an electric solenoid.
Sometimes it is nice to be able to break the rear tires loose
Some Cherokees had a 2 WD and fulltime 4WD choice on the transfer cases but it was manually controlled
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 01-10-2009, 01:02 AM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Your right. I have a Jeep Cherokee. The fulltime 4WD was only available on the older Cherokees with the automatic tranny and it was called the Quadra Track system. A separate handle on the center console allows manual selection of 2 wheel Hi, 4 wheel fulltime (can be used on hard pavement0, 4 wheel part time (for off road), and 4 wheel low range.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
