02-03-2009, 05:44 AM
Re: 07 runs bad when at red light
easist way to solve that is avoid RED LIGHTS...
You are such a goofball
Try some injector cleaner?
Mine has always idled low/little rough....but I like it that way
02-03-2009, 04:18 PM
Doesn't look anything like me...!!! and I have a question BEBE, why do you like it rough ?!!!!!!!!!!!!!
02-03-2009, 04:25 PM
as i was saying earlier...both of mine idol correctly...you can try a fuel additive or injection cleaner, change the fuel filter, check for loose connections to the plugs, burn a tank of premium and if all of that fails go to the dealer and have the mechcanic take a ride with you...first off go to StarBucks and buy Him a large latte and a muffin then hit a bunch of red lights...take a mechcanic, not the service writer...and by the way, settle on only one dealers and make sure you bring your REGULAR Service Writer (always use the same one) a bottle of WINE every June and just before Christmas...
02-04-2009, 06:55 PM
Thanks for the info, I do keep up with good mantanance on the truck but this has me stumped. The rough running seems to be after warmup and has progressivly gotten wrose over time. I know the I5 has a little vibration but not this much. I'll keep posting what I find.
What is the correct RPM at idle?
Brad
2007 Lux w/adventure
White and Ebony
Navigation
02-05-2009, 02:18 AM
it should be in the book...
mine's lost !
02-06-2009, 12:54 AM
I would check the camshaft position solenoid. If you can rotate it without removing the hold down bolt it needs to be replaced. Also if you remove it and any of the screens are missing where the oil feed holes are, again it needs to be replaced. These two problems can cause idle issues without setting codes but usually do set a code
02-06-2009, 05:05 PM
If it only runs rough at idle after it warms up it probably is going to need a head. Even a few 07's have had bad heads. Not nearly as bad as early 06's though. Has your check engine light came on?
02-08-2009, 04:00 PM
Checking the TACK mine seems to be in the 600 range
02-08-2009, 10:00 PM
X2 since new its been around 600 nice and steady
Hybrid Mode
