Old 02-01-2011, 05:39 AM
Default Re: BATTERY DEAD...AGAIN...fml
Originally Posted by navigator32v
. Also, H3's have rundown protection which can take power from other systems.
Technically not true. Rundown ptotection does NOT take power from another system.
Old 02-19-2011, 12:59 PM
Make certain you remove the key from the ignition. Whenever the wife borrows my H3 she fails to key off all the way when leaving key in and it stays on and fries the battery overnite...
It seems like the key is off when in fact it is on. Over time it will lock up your ignition. The battery will be dead and you wont be able to even remove the key from the ignition.
