Old 03-27-2011, 01:27 PM
HumminNBoatin''s Avatar
Default Re: Uneven tire wear
Check your hubs AND balljoints. I have had this problem as well. Most alignment techs do a shake down of your front end. But with the H2 you need to use a prybar to really check the lower balljoints. You cant just shake it down by hand to check the lower ball joints unless you are literally superman.
Just jack the truck up via the fram or lower controll arm untill the tire is about 2" off the ground. Shove a prybar underneigth the tire and lift. Look at the lower ball joint and see if there is any play.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
