Old 11-23-2011, 01:47 AM
Default Re: Exhaust Gasket leak and stud broke
Originally Posted by cashville
btw, the one you used is identical to this right?
http://www.pipelinesupply.com/images...ud_Remover.jpg
Regards
No, the one I use is like this...
Much slimmer, easier on...
Mark
Old 11-23-2011, 10:51 PM
cashville cashville is offline
cashville is on a distinguished road
Ok, I was able to take the broken bolt out with a pair of vise grips.
After that I put the new studs, and I re-used the same gasket because the only ones I could find for sale that would ship to my country were Felpro, and I heard a lot of mixed feedback, so I just re-used the gaskets.
I tightened all the bolts a first pass to 11lbs, and a second to 18lbs, like in the manual.
I noticed that where the broken bolt was, with the new bolt tightened to 18lbs, the header was still not even making contact with the manifold, so I had to tighten it really hard to get it to make contact. (It probably stayed a lot of time with the bolt broken, so it got bent out of shape)
Then, I connected the spark plug wires, and turned on the engine, but the noise is still there, A LOT more quieter now, but it's still leaking air, I can hear it.
Now, I don't know what I should do, if I should tighten all the bolts a little bit more, especially the one where the broken one was, or maybe it can be a leak from the gasket, although I don't think so.
What do you think, should I tighten the bolts a little bit more tomorrow?
Old 11-23-2011, 11:13 PM
Easy Ed Easy Ed is offline
I had to double checked the torque specs and you do have them correct but while looking at the manual it did say not to use the old gaskets. I am afraid it may be the gasket that is the problem now
I would hate to see you tighten the bolts more than the 18 foot pounds and either strip out the threads in the head or break another head of a bolt off.
The call is yours and I know it is not cheap to get the gaskets sent to Portugal but I would get the new ones and do it right and hope for the best
Good luck, Ed
Old 11-23-2011, 11:29 PM
At least the last bolt will have to be tightened at more than 18lbs, because like I said, at 18lbs, there was still a gap between the header and the manifold on that one... The only bolt I have overtightened now, is that last one, that is on the place of the broken one... Maybe if I tighten that one a little bit more, it will stop making the sound, I don't know
I'm thinking like that because, if there was a gap at 18lbs, then maybe I haven't fully closed it at the torque I have on it right now, maybe a little more would close it good.
I'm afraid that it will brake with time, but if I don't overtighten that bolt, then I have a big gap that lets all the air out...
Old 11-23-2011, 11:43 PM
The bolt should handle the extra torque because of the grade it is, guess it is worth a try.
Edit: max torque dry looks to be 24 to 27 foot pounds for a 8 mm 10.9 grade.
Good luck, Ed
Old 11-24-2011, 12:06 AM
I'm not even sure at how much torque the last bolt is, because it's the only bolt with bad access, and my torque wrench wouldn't fit in that place. After the others I could get a feeling of the 18lbs, and put it around that, and I did but it was not enough to close the gap. After that I tightened it a lot, because a lot was needed for the header to go back into place with no gaps.
What I'm thinking of doing tomorrow, is do a leak test and spray some wd40 around the manifold (will start with the place where the broken bolt was), and see if I get a different engine idle, just to detect the leak and make sure it's really coming from that place.
Old 11-24-2011, 02:23 AM
I couldn't wait till tomorrow, so I tightened the last bolt as much as I could, and turned on the engine. the noise was still there, so that didn't help. I then sprayed wd40, and noticed bubbling coming from the gasket at that last bolt. I turned off the engine, and unscrewed the last bolt a little, to not leave it there overtightened.
So, I guess I'm investing in a Felpro gasket. Lol.
Old 11-25-2011, 08:09 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
Mark
How does one aquire 1 of these Stud removers?
Old 11-25-2011, 12:37 PM
99% of my tools are bought from the Snap On or Mac truck when they come to my shop... Once in a while if it?s a tool that I?ll only use once or twice, I?ll go to like a Northern Tool if you have one.
Or do a search...
Rocky Mountain ATV
Pelican Parts
Torque Stick
Mark
Old 11-25-2011, 05:39 PM
Although I already took mine out, I purchased one stud remover from ebay, in case I need it in the future:
http://www.ebay.com/itm/NEW-MATCO-3-...25993305940048
Old 11-29-2011, 05:03 AM
I already have a seller who is going to send me exhaust gaskets at a good price. The gaskets is all I need, or do I need some kind of sealant or something like that to put on the gasket prior to putting them in place?
Old 11-29-2011, 02:15 PM
Depending on the brand you use, will determine whether you use sealant or not.
The copper ones, the ones with the built in rings, blah, blah, blah don't use gaskets. The old style (which I prefer) are made out of a paper/cotton sort of soft material and generally are able to be doubled up if necc and/or add sealant.
Mark
Old 11-29-2011, 03:33 PM
I bought a FelPro, should I use anything on it?
Old 12-01-2011, 07:49 PM
bump
