Old 10-31-2013, 01:00 AM
Inspignant Inspignant is offline
Inspignant is on a distinguished road
Default Re: DRL not working / All fuses, relays and bulbs good
I will check the HID relays that come with the kit. I need to mention that the DRL's used to work when I first installed the HID's. I also have not done the mod yet for the DRL and Headlights on at the same time yet since I noticed the problem with the DRL's not working anymore.
New DRL bulbs
New DRL relay installed correctly
New Fuse
Working Light sensor (checked with flashlight at night) Headlights go off but DRL's dont come on.
Old 10-31-2013, 11:22 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
The HID's should be wired completely separate from the DRL's and should have nothing to do with them not working.
As FYR said double check your wire and diode that it's in the right direction for the DRL mod. That honestly is the only thing that has changed and they no longer work.
Old 11-01-2013, 01:04 AM
Thanks guys, I will be digging into this, this weekend. Seems I am having more issues now. The Cruise control is not working now, and it worked last week. Will update with findings. Thanks again.
Old 11-01-2013, 09:35 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
I just did this mod too and the same thing happened. I metered it and there is no longer voltage coming from the BCM. Apparantly, the voltage going backwards to the BCM from doing the mod fries the transistor that switches it. Now I just have the DRL on with the headlights. I'll just live with it instead of buying another BCM module. Others have gone years with no problems.
Old 11-02-2013, 12:45 AM
LoJac963's Avatar
Oh **** I hope that's not what happens when you install it backyards!!
Hope you guys get this worked out. Keep us updated!
Old 11-02-2013, 04:22 AM
Im sure installing it backwards could probably fry something but I am positive that is not the case. I do however think that the Anti flicker capacitor that is installed in the HID system could be the reason that the DRL's are not working. I have emailed the company and hope to hear back from them soon.
Spending over 90 hours a week working on private jets is all fun and games but do I really want to go home and spend more time troublshooting an electrical problem when I could come here and possibly get lucky and find the answer to my problem.
(As he says in a sarcastic tone and quoting a line from THE MASK)
I'd like to think so, Haa Haa
Old 11-02-2013, 04:34 AM
And yes, I will keep you posted.
