Old 07-01-2014, 07:21 PM
Hellz Hellz is offline
Default Re: HELP! Can't get key to turn to remove ignition switch
well, there are a few threadss about the ignition key issue... im sure a simple seearch would pull them up...
ill help you out and narrow your choices down.
1. call a tow and have your H2 towed to a dealer who will replace your ignition switch, and charge alot of $$$
2. search this forum for ignition switch issues and see the pics. get a drill and drill through the plastic and use the drill bit, or something else that can rach the ignition key button release to get your key out.
bottom line, you will need to replace your ignition switch, unless you keep doing step #2 to press the button to release the key.
