Old 08-12-2015, 07:02 AM
finall finall is offline
Default Re: high-pitched squeel on highway curves
Originally Posted by H2005
Sounds like bearings to me. Usually you will hear them when turning and they will make a clicking noise when it's pushed in neutral.
So here is the weird thing, which makes me wonder if it is a bearing or not. There is none of that tell-tale clicking sound when a pin bearing goes. Not sure what kind of bearings the H2 has.
You can only hear the squeal at highway speed, not noticeable at all at low speed. I will try to push it in neutral with engine off, to see if I hear anything. Thanks for that suggestion.
Old 08-16-2015, 05:36 AM
jrs2005's Avatar
jrs2005 jrs2005 is offline
jrs2005 is on a distinguished road
Stock wheel and tire sizes? Any change if you lock the transfer case? On the gas or off make any difference?
Old 08-16-2015, 07:06 AM
Yes, stock wheels and tires. On or off the gas makes no difference.
I have not locked the transfer case. It is in 4 high, because I think it has to be at 65+mph on dry roads?
Old 08-19-2015, 03:05 AM
jrs2005's Avatar
I guess I'd find a lift somewhere and start rotating stuff one part at a time. See if there is any play in the bearings once the truck weight is unloaded. Good luck.
