Old 04-06-2003, 08:49 PM
COREY COREY is offline
COREY is off the scale
1 Phillips screw behind door handle and remove square panel. Then 2 bolts behind plastic panel need to be removed.I think they are 8mm. Then get your fingers inside on the bottom of the door panel and give a swift pull straight out, being careful not to break plastic pins. Should pop right out. Good luck....
