Old 06-15-2005, 11:27 AM
Frank2005's Avatar
Frank2005 Frank2005 is offline
Frank2005 is off the scale
Should my driver positions automatically set depending on which key fob I open the door with? My wife has an Envoy that works that way. On the H2 it seems that you have to use the # on the door to switch driver positions. Thanks,
Frank
2005 H2 SUT Lux *sold*
Frank2005's Avatar
Frank
Old 06-15-2005, 12:02 PM
The number on the fob should corresponde to the number on the door and it's settings.
Old 06-15-2005, 12:49 PM
Texas Red's Avatar
Texas Red is off the scale
I think the 2005 H2's dropped that feature. My 2003 adjusts the seat when I unlock with the fob.
Jim
2008 H3 Graphite Lux
Old 06-15-2005, 12:56 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Texas Red:
I think the 2005 H2's dropped that feature. My 2003 adjusts the seat when I unlock with the fob. </div></BLOCKQUOTE>Mine's the same as yours. That bites if they changed it.
Old 06-15-2005, 01:02 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
O5 changed that feature, no automatic seat adjustment, you must push the pbutton on the door panel. If you use the easy seat exit, then the damn thang doesn't goe back into position. You want notice until your driving, then you have to stop put it in park, and push the stupid button before the seat will return to the desired location...
Old 06-15-2005, 01:24 PM
tower's Avatar
tower tower is offline
That blows!
Old 06-15-2005, 01:49 PM
Frank2005's Avatar
Then why bother numbering the fobs?
Old 06-15-2005, 01:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Frank2005:
Then why bother numbering the fobs? </div></BLOCKQUOTE>Leftover '03's.
Old 06-17-2005, 06:26 PM
CONRAD II's Avatar
I have an 05 sut and the entire seat memory feature sucks. The worst part is the easy exit feature, if you don't push the desired seat setting before putting the car in gear you have to stop, put the truck in park, and then push the memory button you want. I guess gm feels like the seat shouldn't be able to adjust to any one saved setting unless the truck is in park, but I can manually adjust my seat while driving. That makes no sense at all. I have just turned the easy exit off and keep the seat in the same position all the time.
66' VETTE STINGRAY
07' Z06
Old 06-17-2005, 06:44 PM
Now if you want something to bug you, try looking at the steering wheel in relation to the dash and tell me why it’s offset on one side? </div></BLOCKQUOTE>Man, that's just wrong.
Old 06-18-2005, 04:20 AM
MUH_HUM MUH_HUM is offline
MUH_HUM is off the scale
So my wife could get the number 1 fob, and I could get number 2. It's my truck, but it's her world, and I just live in it.
Old 06-18-2005, 03:11 PM
Hummertech is off the scale
In 05 they dropped that feature of the fobs selecting driver 1 or 2. However, you can go to your local Hummer dealer and ask them to enable this feature like on the older H2's. Then they have to call GM to get a special program number called a VCI number, and they can reprogram your truck to work that way. If you plan on doing this you may want to print this up and show it to your dealer because most dealers are probably in the dark that you can do this.
Old 06-22-2005, 01:45 PM
Now if you want something to bug you, try looking at the steering wheel in relation to the dash and tell me why it’s offset on one side? </div></BLOCKQUOTE>It's to make you fully aware that you are not driving in the UK.
Anyway, it's centered in the dash opening, just not centered on the seat.
Old 06-22-2005, 02:07 PM
LoLo's Avatar
LoLo LoLo is offline
LoLo is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MUH_HUM:
So my wife could get the number 1 fob, and I could get number 2. It's my truck, but it's her world, and I just live in it. </div></BLOCKQUOTE>
Glad you see it OUR way! Most men haven't figured that out, yet!
___________________
05 Desert Sand H2 Adv
Old 06-24-2005, 01:44 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by LoLo:
Glad you see it OUR way! Most men haven't figured that out, yet! </div></BLOCKQUOTE>
Well, most men have their heads in their asses, and I am no exception.
