Old 10-26-2005, 06:41 PM
psywzrd psywzrd is offline
psywzrd is off the scale
My H3 is making a very light grinding noise at low RPMS (1500-2000). It sounds like it's coming from the engine on the passenger's side but it's tough to pinpoint when you're driving. Anyone else hearing this? It may be perfectly normal but I only noticed it recently when I had my radio on really low. Maybe "light grinding noise" isn't the best way to describe it but it sounds like a fan or something that's not spinning freely. Anyone?
Old 10-26-2005, 07:08 PM
xburbman xburbman is offline
xburbman is off the scale
[quote]Originally posted by psywzrd:
[quote]Originally posted by xburbman:
On a serious note...I haven't heard anything like that. However, I do have 2 small noises that I'm going to have the dealership fix. 1 is when it's at a stop/low idle...it's from the very back of the truck(I think it's the headliner frame)..definitely plastic vibration. The other is when the Moon roof closes..a metal against metal screech...probably just needs oil or graphite. If its a sound that's buggin you, it's not normal. When I drive around normally, the truck is extremely quiet...except when I have XM radio at 8 decibels.
wsp
Old 10-26-2005, 06:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by xburbman:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by psywzrd:
My H3 is making a very light grinding noise at low RPMS (1500-2000). It sounds like it's coming from the engine on the passenger's side but it's tough to pinpoint when you're driving. Anyone else hearing this? It may be perfectly normal but I only noticed it recently when I had my radio on really low. Maybe "light grinding noise" isn't the best way to describe it but it sounds like a fan or something that's not spinning freely. Anyone? </div></BLOCKQUOTE>
Hmmmm....Grinding Noise?.....psywzrd?....Dr. Ruth may need to provide an answer. </div></BLOCKQUOTE>
Now that's some funny $hit!!! Not too many people pick up on my nick...
But, unfortunately, this is most definitely a different kind of grinding noise
Old 10-26-2005, 10:12 PM
On a serious note...I haven't heard anything like that. However, I do have 2 small noises that I'm going to have the dealership fix. 1 is when it's at a stop/low idle...it's from the very back of the truck(I think it's the headliner frame)..definitely plastic vibration. The other is when the Moon roof closes..a metal against metal screech...probably just needs oil or graphite. If its a sound that's buggin you, it's not normal. When I drive around normally, the truck is extremely quiet...except when I have XM radio at 8 decibels. </div></BLOCKQUOTE>
I hear you - I usually have the XM cranked myself. The thing is, it's probably going to be kind of tough to get this fixed because:
A. It doesn't happen all the time
AND
B. It's not something really obvious that I can easily point out or show to the service manager.
With my luck my H3 won't make the noise when they check it, but it'll be even worse when I get it back from service.
Again, this might be totally normal and I'm just nitpicking but if something is wrong I'd like to get it fixed before it possibly escalates into something bigger.
Old 10-26-2005, 06:48 PM
wsp
