Old 01-18-2005, 11:31 PM
Kevin B Kevin B is offline
Kevin B is off the scale
I am getting ready to re-rubber my Hummer and am having trouble deciding between 37x12.5s and 35x13.5s. I am concerned with rubbing and power loss issues by going with the 37s. On the plus side im thinking it will help the breakover angle and groung clearance.
I usually play in sand and rock so the 13.5 width should help with the ground pressure. If I went with the 37x13.5s im sure to have problems (dont want a lift).
Any feed back from those of you who are running 37s would be nice. Thanks, Kevin.
