Old 04-06-2003, 03:20 PM
HummerGUY HummerGUY is offline
HummerGUY is off the scale
I know I posted this before, but maybe someone can clarify, I know the door panels are held on by clips, but how exactly do I go about poping them off. Any help is appreciated!
Old 04-06-2003, 08:49 PM
COREY COREY is offline
COREY is off the scale
1 Phillips screw behind door handle and remove square panel. Then 2 bolts behind plastic panel need to be removed.I think they are 8mm. Then get your fingers inside on the bottom of the door panel and give a swift pull straight out, being careful not to break plastic pins. Should pop right out. Good luck....
