Old 04-14-2006, 05:26 PM
Arizona Hummerboy's Avatar
I have a after market Sunroof, it is a Webastohollandia Stratos 700 Sunroof.
Does anyone know of what kind of Lube I can use on it.
The problem I had with it is, the Sunroof got stuck open on me while I was doing a Snow Run and I could not get the Sunroof to Close. And yes it was Snowing on me.
I reprograme the Sunroof, and it now works, and I just need to Lube or Grease it.
And yes I am to cheep to take it to the Dealership to have it Lube. I am afraid to see what it would cost to have it done at the Dealership.
Old 04-14-2006, 09:56 PM
dochummer's Avatar
Yeah...I remember the "other link."
'03 H2
Old 04-14-2006, 09:57 PM
dochummer's Avatar
Atleast the sunroof works. Mine started making vibrating sounds not too long after I purchased the vehicle. Some day, when I get the courage up to pull the headliner, i'll fix it...
'03 H2
Old 04-15-2006, 01:08 AM
Silicone should be avialable at a large home improvement store, or garage door retailer.
Old 04-15-2006, 07:20 PM
Thanks for the Information.
I did the Silicone, and the Sunroof works much better now.
Old 04-16-2006, 12:51 PM
It\'s a Dry Heat's Avatar
I have a after market Sunroof also. I need too do mine also. Thanks for the info.
Old 05-17-2006, 04:20 PM
menuserve.com menuserve.com is offline
menuserve.com is on a distinguished road
Default Re: SUNROOF LUBE
what kind of sunroofs did you have installed... who did it... and at what cost?
Old 05-18-2006, 05:34 AM
It is a Webastohollandia Stratos 700 Sunroof. Scottsdale Hummer did the install on it, it was in the cost of the Hummer, I not sure of the price of it.
Old 05-18-2006, 03:21 PM
so... if i bring a 2003 hummer into the dealer... will they do an install now or do i have to go to some aftermarket place to get this done?
:: 2003 H2 WHITE/GREY ::
:: Free Online Dating :: Restaurant Takeout & Delivery Menus ::
Old 05-19-2006, 01:14 AM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Originally Posted by Alec W
I used silicon lube on mine.
Google for it but you’ll have to sort through some of the other links for lube
Yup good stuff.
Old 05-19-2006, 03:16 AM
Some dealership can do it there, and then some dealership will send it out to be done. You may want to check with your dealership, to see if they can do it for you.
Old 05-19-2006, 11:30 AM
any idea on what kind of price it will be?
