Old 03-20-2006, 09:08 PM
bigolH2 bigolH2 is offline
bigolH2 is off the scale
Hey guys, im havin trouble installing the superchip programmer. The programmer wont get past the initializing part and then it states that theres a code 038 error. anyone know whats going on with it? thanks!
03 White H2 with Banks exhaust, Volant intake, 4\" Rancho lift, 18\" black Rockstars, 37\" ProComp Xterrains, Roof Rack and lights and a lot of turning heads!
Old 03-20-2006, 10:10 PM
Kevin B Kevin B is offline
Kevin B is off the scale
Not trying to be a wise guy or anything but are you sure you pulled the right fuse? Did it say "info 15 amp"?
Old 03-20-2006, 10:21 PM
lol, I hear ya. Actually, there wasnt even a fuse in there.
Old 03-21-2006, 12:05 AM
kodiakz kodiakz is offline
kodiakz is off the scale
There are actually 3 or 4 fuses that need to be pulled. Anything to do with onsar, radio or amp needs to be pulled.
Old 03-21-2006, 12:09 AM
I thought that was only if they were aftermarket .
Old 03-21-2006, 01:33 AM
No, oem databus communications. Actually, the programming can fail if your onstar takes an update or tries to communicate with the radio. Directly from my superchips manual, it says to remove the following fuses: from the driver side fuse panel, remove SEO ACCY; from the exterior fuse panel, remove SEO B1, SEO IGN, INFO, SEO B2, RADIO, and RADIO AMP. I had to try mine 3 or 4 times before it worked properly.
Old 03-21-2006, 05:51 AM
vip808 vip808 is offline
vip808 is off the scale
It might be your battery.. i remember reading a GM techlink that you need to have your battery fully charged and that they have their mechanics connect a battery charger whenever they reprogram or flash the computer... i was trying to post a link but i can't get into gmtechlink.com
Old 03-21-2006, 06:08 AM
Here's the link
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/2...171037631#2171037631
Old 03-21-2006, 10:54 AM
yall rock, thanks for the info! ill give it a try today and see how it goes. the info15 was out and it still have me the error code so ill try the other 30 fuses later! take it easy boys!
