Old 01-29-2004, 12:22 AM
Rbohno Rbohno is offline
Rbohno is off the scale
I get a bad bog or hesitation upon starting off after my truck has sitting for approximately an hour after it has been warmed up. If I gas it , it will backfire , if I let off and then gas it again it runs fine. It will only do it 3 or 4 times a week and it doesnt last long enough to trigger a code.
Does anyone have any ideas? My brother is a mechanic at one of the local G.M. Dealerships and said maybe an injector was bleeding down.???
Any Ideas ???
Rich
\'03 White Lux
Any Ideas ???
Rich
\'03 White Lux
Old 01-29-2004, 12:52 AM
Klaus's Avatar
Klaus Klaus is offline
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Service Information</TITLE>
<META http-equiv=Content-Type content="text/html; charset=windows-1252">
<META content="MSHTML 6.00.2800.1276" name=GENERATOR></HEAD>
<BODY bgColor=#ffffff>
<FORM name=topNavForm action=/servlets/CellHandler>
<TABLE width="100%" align=center>
<TBODY>
<TR>
<TD width="25%" slign="LEFT"><INPUT onclick="java_script: history.back[);" type=button value="<- Back" name=back><INPUT onclick="java_script: history.forward[);" type=button value="Forward ->" name=forward>
</TD>
<TD align=middle width="50%">Document ID# 839436
2003 HUMMER
H2
</TD>
<TD align=right width="25%"><INPUT onclick="java_script: window.print[);" type=button value=Print name=print>
</TD></TR></TBODY></TABLE>
<HR>
</FORM>
<H1>Backfire</H1>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=bottom align=middle>
Inspections</P></TH>
<TH vAlign=top align=middle>
Actions</P></TH></TR>
<TR>
<TD vAlign=top align=left colSpan=2>
DEFINITION: Fuel ignites in the intake manifold or in the exhaust
system, making a loud popping noise.</P></TD></TR>
<TR>
<TD vAlign=top align=left>
Preliminary Inspections</P></TD>
<UL type=BULLET>
<LI>Refer to Important Preliminary Inspections Before Starting in <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30562&amp;RefDoc=839436">Sympto ms
- Engine Controls</A> .
<LI>Search for bulletins.
<LI>Verify that the powertrain control module (PCM) grounds are clean,
tight, and in the proper locations. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62050&amp;RefDoc=839436">Power
and Grounding Component Views</A> in Wiring Systems and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30158&amp;RefDoc=839436">Engine
Controls Schematics</A> . </LI>[/list]</TD></TR>
<TR>
Fuel System</P></TD>
<UL type=BULLET>
<LI>Inspect for incorrect fuel pressure. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30144&amp;RefDoc=839436">Fuel
System Diagnosis</A> .
<LI>Inspect for a contaminated fuel condition. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30353&amp;RefDoc=839436">Alcoho l/Contaminants-in-Fuel
Diagnosis</A> .
<LI>Inspect the fuel injectors. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30125&amp;RefDoc=839436">Fuel
Injector Coil Test</A> , <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30403&amp;RefDoc=839436">Fuel
Injector Balance Test with Special Tool</A> or <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30404&amp;RefDoc=839436">Fuel
Injector Balance Test with Tech 2</A> .
<LI>Verify that each injector harness is connected to the correct
injector or cylinder. Relocate injector harnesses as necessary.
<TR>
Sensor/System</P></TD>
<UL type=BULLET>
<LI>Inspect the air intake system and crankcase for air leaks.
<LI>Inspect the crankcase ventilation valve for proper operation. Refer
to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=65607&amp;RefDoc=839436">Crankc ase
Ventilation System Inspection/Diagnosis</A> in Engine Mechanical.
<LI>Inspect for an inaccurate speedometer. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=51427&amp;RefDoc=839436">Sympto ms
- Instrument Panel, Gages and Console</A> in Instrument Panel, Gages,
and Console.
<LI>Use a scan tool in order to monitor the knock sensor (KS) system for
excessive spark retard activity. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30557&amp;RefDoc=839436">Knock
Sensor (KS) System Description</A> . </LI>[/list]</TD></TR>
<TR>
Ignition System</P></TD>
<UL type=BULLET>
<LI>Inspect for proper ignition voltage output with J 26792
Spark Tester .
<LI>Remove spark plugs and inspect for the following:
<UL type=SQUARE>
<LI>Wet plugs
<LI>Cracks
<LI>Wear
<LI>Improper gap
<LI>Burned electrodes
<LI>Heavy deposits </LI>[/list]</LI>[/list]
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30554&amp;RefDoc=839436">Spark
Plug Inspection</A> .</P>
<UL type=BULLET>
<LI>An improper spark plug gap will cause a driveability problem. Refer
to <A
Plug Inspection</A> . Gap the spark plugs using a wire gage gap tool .
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30325&amp;RefDoc=839436">Spark
Plug Replacement</A> .
<LI>Determine the cause of the fouling before replacing the spark plugs.
Refer to <A
Plug Inspection</A> for diagnosis.
<LI>Visually and physically inspect secondary ignition for the
following:
<UL type=SQUARE>
<LI>Ignition wires arcing to ground
<LI>Ignition coils arcing to ground </LI>[/list] <LI>Soak the secondary ignition system with water from a spray bottle.
Soaking the secondary ignition system may help locate damaged or
deteriorated components. Look and listen for arcing or misfiring as you
apply the water.
<LI>Monitor the Misfire Current Counters while driving the vehicle in
the conditions that the misfire occurred. If a misfiring cylinder can be
located, use the DTCP0300 table for diagnosis. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30479&amp;RefDoc=839436">DTC
P0300</A>
<LI>Inspect for loose ignition coil grounds. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30190&amp;RefDoc=839436">Electr onic
Ignition (EI) System Diagnosis</A> . </LI>[/list]</TD></TR>
<TR>
Engine Cooling System</P></TD>
<UL type=BULLET>
<LI>Inspect the engine coolant level for being low. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=37222&amp;RefDoc=839436">Loss
of Coolant</A> in Engine Cooling.
<LI>Inspect the engine thermostat for proper operation and for the
correct heat range. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=37167&amp;RefDoc=839436">Thermo stat
Diagnosis</A> in Engine Cooling. </LI>[/list]</TD></TR>
<TR>
Engine Mechanical</P></TD>
<UL type=BULLET>
<LI>Inspect engine mechanical for the following:
<UL type=SQUARE>
<LI>Compression--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=43985&amp;RefDoc=839436">Engine
Compression Test</A> in Engine Mechanical.
<LI>Sticking or leaking valves
<LI>Worn camshaft lobes
<LI>Valve timing
<LI>Bent push rods
<LI>Worn rocker arms
<LI>Broken valve springs
<LI>Excessive oil in combustion chamber or leaking valve seals--Refer
to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44067&amp;RefDoc=839436">Oil
Consumption Diagnosis</A> in Engine Mechanical. </LI>[/list] <LI>For incorrect basic engine parts. Inspect the following:
<UL type=SQUARE>
<LI>The camshaft--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44059&amp;RefDoc=839436">Camsha ft
and Bearings Cleaning and Inspection</A> in Engine Mechanical.
<LI>The cylinder heads--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44030&amp;RefDoc=839436">Cylind er
Head Cleaning and Inspection</A> in Engine Mechanical.
<LI>The pistons, etc.--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44085&amp;RefDoc=839436">Piston ,
Connecting Rod, and Bearings Cleaning and Inspection</A> in Engine
Mechanical. </LI>[/list] <LI>Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44155&amp;RefDoc=839436">Sympto ms
- Engine Mechanical</A> in Engine Mechanical for diagnosis procedures.
<TR>
Additional Inspections</P></TD>
<UL type=BULLET>
<LI>Visually and physically inspect the vacuum hoses for splits, kinks,
and proper connections and routing as shown on the Vehicle Emission
Control Information label.
<LI>Inspect the intake manifold and the exhaust manifold passages for
casting flash.
<LI>Inspect the transmission torque converter clutch (TCC) operation.
The scan tool should indicate an RPM drop when the TCC is commanded ON.
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=75303&amp;RefDoc=839436">Diagno stic
System Check - Automatic Transmission</A> in Automatic
Transmission-4L60-E.
<LI>Inspect the exhaust system for possible restrictions. Inspect the
following:
<UL type=SQUARE>
<LI>Inspect the exhaust system for damaged or collapsed pipes.
<LI>Inspect the mufflers for heat distress or possible internal
failure.
<LI>Inspect for possible plugged catalytic converters. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62242&amp;RefDoc=839436">Restri cted
Exhaust</A> in Engine Exhaust. </LI>[/list]</LI>[/list] <UL type=BULLET>
<LI>Electromagnetic interference (EMI) on the reference circuit can
cause an engine miss condition. A scan tool can usually detect EMI by
monitoring the engine RPM. A sudden increase in RPM with little change
in actual engine RPM change may indicate that EMI is present. If a
problem exists, inspect for high voltage components near the ignition
control circuits.
<LI>Inspect the park/neutral position (PNP) switch operation. Refer to
<A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=6964&amp;RefDoc=839436">Park/Neutral
Position Switch Adjustment</A> in Automatic Transmission-4L60-E.
<LI>Inspect for faulty motor mounts. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44042&amp;RefDoc=839436">Engine
Mount Inspection</A> in Engine Mechanical.
casting flash </LI>[/list]</TD></TR></TBODY></TABLE>
<FORM name=bottomNavForm>
<HR>
<TBODY>
<TR>
</TD>
2003 HUMMER
H2
</TD>
</TD></TR></TBODY></TABLE></FORM></BODY></HTML>
Old 01-29-2004, 12:55 AM
Klaus's Avatar
<TBODY>
<TR>
</TD>
<TD align=middle width="50%">Document ID# 839324
2003 HUMMER
H2
</TD>
name=print>
<HR>
</FORM>
<H1>Hesitation, Sag, Stumble</H1>
<TBODY>
<TR>
Inspection/Tests</P></TH>
Action</P></TH></TR>
<TR>
DEFINITION: Momentary lack of response as the accelerator is pushed
down. Can occur at any vehicle speed. Usually more pronounced when first
trying to make the vehicle move, as from a stop. May cause the engine to
stall if severe enough.</P></TD></TR>
<TR>
Preliminary</P></TD>
<UL type=BULLET>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30562&amp;RefDoc=839324">Sympto ms
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30158&amp;RefDoc=839324">Engine
<TR>
Inspect the manifold absolute pressure (MAP) sensor
operation.</P></TD></TR>
<TR>
<UL type=BULLET>
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30144&amp;RefDoc=839324">Fuel
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30353&amp;RefDoc=839324">Alcoho l/Contaminants-in-Fuel
Diagnosis</A> .
<LI>Verify that both fuel injector fuses are not open. An open fuel
injector fuse causes 4ignition coils and 4fuel injectors not
to operate. Inspect the ignition coil circuits and the fuel injector
circuits for an intermittent short to ground. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=62194&amp;RefDoc=839324">Circui t
Testing</A> and <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=61965&amp;RefDoc=839324">Wiring
Repairs</A> in Wiring Systems. Replace the fuse.
<LI>Inspect for the following that may cause the engine to run rich:
<UL type=SQUARE>
<LI>
<H4><FONT color=blue>Notice</H4></FONT>
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=10174&amp;RefDoc=839324"><FONT
color=blue>Heated Oxygen and Oxygen Sensor Notice</FONT></A> in
Cautions and Notices.</P>Water intrusion in the heated oxygen sensor
(HO2S) connector
<LI>Engine oil contaminated by fuel
<LI>An evaporative emission (EVAP) canister purge condition
<LI>Incorrect fuel pressure--Refer to <A
<LI>Leaking fuel injectors--Refer to <A
<LI>An inaccurate mass air flow (MAF) sensor
<LI>Blockage on the inlet screen of the MAF sensor--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30405&amp;RefDoc=839324">Mass
Air Flow (MAF)/Intake Air Temperature (IAT) Sensor Replacement</A> .
<LI>Vacuum hoses that are split, kinked, or improperly connected
<LI>An air intake duct that is collapsed or restricted--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=69209&amp;RefDoc=839324">Air
Cleaner Resonator Outlet Duct Replacement</A> .
<LI>An air filter that is dirty or restricted--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30328&amp;RefDoc=839324">Air
Cleaner Element Replacement</A> . </LI>[/list] <LI>Inspect for the following conditions that may cause the engine to
run lean:
<UL type=SQUARE>
<LI>
Refer to <A
Cautions and Notices.</P>Water intrusion in the HO2S connector
<LI>An exhaust leak between the HO2S and the engine--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=37907&amp;RefDoc=839324">Exhaus t
Leakage</A> in Engine Exhaust.
<LI>Vacuum leaks
<LI>Restricted fuel injectors--Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30403&amp;RefDoc=839324">Fuel
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30404&amp;RefDoc=839324">Fuel
<LI>An inaccurate MAF sensor
<LI>Fuel contamination--Refer to <A
Diagnosis</A> .
</LI>[/list]</LI>[/list]</TD></TR>
<TR>
<UL type=BULLET>
apply water.
<LI>Test for proper ignition voltage output with the J 26792
Spark Tester . Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30190&amp;RefDoc=839324">Electr onic
Ignition (EI) System Diagnosis</A> for the procedure.
<LI>Remove the spark plugs and check for the following:
<UL type=SQUARE>
<LI>Correct heat range
<LI>Wet plugs
<LI>Cracks
<LI>Wear
<LI>Improper gap
Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30554&amp;RefDoc=839324">Spark
<UL type=BULLET>
<LI>An improper spark plug gap will cause a driveability problem. Gap
the spark plugs using a wire gage gap tool. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30325&amp;RefDoc=839324">Spark
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=30479&amp;RefDoc=839324">DTC
P0300</A> .
<TR>
Inspect the engine thermostat for proper operation and for proper heat
range. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=37167&amp;RefDoc=839324">Thermo stat
Diagnosis</A> in Engine Cooling.</P></TD></TR>
<TR>
<TD>
<TD>
Inspect for excessive crankshaft endplay that will cause the crankshaft
position (CKP) sensor reluctor wheel to move out of alignment with the CKP
sensor. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=44076&amp;RefDoc=839324">Cranks haft
and Bearings Cleaning and Inspection</A> in Engine Mechanical. This could
result in any of the following conditions:</P>
<UL type=BULLET>
<LI>A no start
<LI>A start and stall
<LI>Erratic performance </LI>[/list]</TD></TR>
<TR>
Inspect the generator output voltage. Refer to <A
href="http://127.0.0.1:9001/servlets/CellHandler?CellId=37779&amp;RefDoc=839324">Diagno stic
System Check - Engine Electrical</A> in Engine Electrical for the
procedure. Repair the charging system if the generator output voltage is
less than 9volts or more than 16volts.</P></TD></TR></TBODY></TABLE>
<HR>
<TBODY>
<TR>
</TD>
2003 HUMMER
H2
</TD>
name=print>
Old 01-29-2004, 01:42 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Hey why can't I go back or forward!!!
Just Kidding,
I'm really not that ignorant!!!
Ric-H2
www.meatspin.com
Old 01-29-2004, 01:58 AM
Hey Klaus,
Thank you very much for the help and taking the time to look up those bulletins.
Rich
\'03 White Lux
Old 01-29-2004, 02:21 AM
Klaus's Avatar
Glad to help. I finally figured out how to post these in HTML format so they look OK.
Rich - When your truck gets fixed, please post an update.
Klaus
Rare 2003 H2 with UM8 Integrated Navigation Radio
Skull & Bones Member since 2003
Old 01-29-2004, 02:31 AM
Klaus,
What`s the meaning of life?
" S & B Member Since 2003 "
Old 01-29-2004, 02:42 AM
Klaus's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by DennisAJC:
Klaus,
<HR></BLOCKQUOTE>
Hell, I don't know... I need to GET a life! I spend way too much time on the net!
Klaus
Old 01-29-2004, 01:48 PM
Jason's Avatar
Jason Jason is offline
Site Admin
Jason has disabled reputation
You guys are too much!!!!
-Jason
www.somo.com - Custom. Accessories. Home of the H2 Source and the H3 Source.
