Old 04-04-2006, 03:36 AM
Motohead's Avatar
Motohead Motohead is offline
Originally posted by Ompus:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Motohead:
i just order a train horn for my H2 that I had on my Ram. at over 150db they will get the point when it goes off if it's hooked to the car alarm.
Thats the one thing that I am dissapointed about regarding the H2 is the horn.. It sounds so tiny compared to the machine its on.
Where are you getting your Train horn? And is it a direct replacement, or do I need so additional hardware?
Thanks </div></BLOCKQUOTE>
from www.hornblasters.com no, its not a direct replacement, it an air compressor with an air tank and 4 horns. It took me about 7 hours to professionally install one in my Ram, fabricating mounting brackets, wiring switches into the cab. Its over 150 db. actually makes your ears hurt if you stand right there. hard to describe. There is so much vehicle underneath the H2. I have laid underneath the H2 for about 2 hours mentally going over what and where i need to fit it. Only space available is right under the air suspension compresors. Going to have to fabricate several brackets, and mount the airtank in the back of the trunk because the new one is 21" long.
heres the one I mounted under the Dodge.
