Old 01-31-2006, 02:35 AM
ptrontheirc ptrontheirc is offline
ptrontheirc is off the scale
Hi, this is my third or fourth time posting on the forum. I have a 2003 H2 with 24000 miles on it. It has a 4 inch lift kit on it, supercharged, with a bunch of stuff from the previous owner professionally installed. The guy did everything by the book, and everything was installed properly. A few days ago I put in the sound system that I moved out of my BMW 740 (2000). Now, the check engine light is on, and its orange in color. The car seemed to be running fine (and still does) but that check engine light is still on. The engine oil is at 27%, which I know needs to be changed, and I will be changing it tomorow. The only problem I am having with the car, is every once in a while, usually in the morning, I go to start the car and I hear nothing from the engine. The radio comes on, the seats move, everything seems to work, but the car doesnt start. I keep turning the key over and over and fiddling with the steering wheel and the shift, and it will eventually turn on. Does anyone have any idea what the problem with this is? When I first bought the car I had this same problem, took it in to the dealership, they couldnt find the problem, but did fix it. Please someone let me know what I should do because I am completely bewildered by this problem.
Thanks alot
Peter Szigeti
- 2003 H2
- 1976 CORVETTE STINGRAY
- 2000 BMW 740I
- 1998 BMW 4 DOOR M3
Peter
