02-07-2003, 09:25 PM
Okay, how about some experienced insights on "How to judge a slope". Do you guys/gals have photos of your off-road machines on slopes of a known angle (or best guess known)? I'd like to have an idea before I get on a slope as to the approximate angle it represents. Or do you just approach it slowly and get a feel for the vehicle attitude?
JJ
01-28-2005, 05:37 PM
You must be having a bad day, Paragon.
I didn't mean to hurt anybody's feelings here - if I did, I apologize. I certainly wasn't trying to start any fights with anyone.
I said what I meant - in every post. When I talk about driving on a slope, you respond with emotionally driven phrases like "your obvious ignorance" - maybe it is just me, but I consider that a personal attack.
I'm done - have fun with yourself...
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PARAGON:
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Manny:
Paragon,
All I said was you should not rely on gauges to tell you when it safe without factoring all the factors involved.
If you have other issues with me personally, please feel free to email me privately; I am not particularly interested in entertaining your other personal attacks and emotionally driven criticisms publicly. <HR></BLOCKQUOTE>The fact is that is not all you said. YOU are the off-road editor of a magazine and now want to edit what you have already written here. Admit it, the connotation of your original post was to completely discount the use of these gauges. Your post can not be interpreted any other way.
This is not like writing a column in a magazine. Write something here and you will be responded to. You were obviously hunting for something when you posted your opinion in a thread that had not been posted to in over a year. So, your self-importance here is of no consequence. If you view my disagreement with your first post in this thread and then your continued attempts to re-write what you said as a "personal attack", maybe you need to reconsider your own emotional state. I can assure you, not much of anything I type in this forum is "emotionally driven."
The simple fact is that, as with everything else in life, when utilized properly, these gauges can be helpful by providing additional information to the driver. <HR></BLOCKQUOTE>
01-18-2004, 07:29 PM
a set of incline and sideslope gauges are key I think...especially when learning. knowing what the limits are and knowing that you can go over those limits is key. I remember the first time I got real sideways... and you start to feel that in the pit of your stomach... check the gauge and realize that you are no where near the limits.
if you get gauges... remember the placement of them IS a big deal.... you cannot put your sideslope gauge up on the roof console...
unaslob
01-28-2005, 06:11 PM
<HR></BLOCKQUOTE>Fine, you simply can't admit that you made a mistake in your first post. You have attempted to backtrack by saying you meant something else. Now, you want to wash it all away by labeling this as a personal attack.
First you say "You should not rely on gauges while performing steep ascents, descents, or sideslopes." You did not say solely rely or rely only on, you said do not rely. Which in effect was saying that the gauge is useless, since you can't rely on it. You proceeded to say "the gauge will not help you" in one of the next sentences. Then you attempt to rewrite those comments by saying "All I said was you should not rely on gauges to tell you when it safe without factoring all the factors involved."
It's truly sad that you can't admit to the difference and the misinformation you provided in the first post.
Then you try to split hairs by saying that my comments about the 45 degree and the H1 were wrong based on what you said. But you again, erroneously, said "most clinometer/inclinometers designed for 4x4 use are useless in a Hummer H1 because they get pinned well before the actual point of rollover threat." This is obviously inaccurate, even as you admit, because MOST actually do go to 45 degrees and a few do not.
Simply put, you came here to a year old thread to talk about your column in a magazine under the guise that you are an expert but when taken to task on your comments, you cry about it. I certainly have nothing to lose/gain by posting my opinions here but you should at least think before you type, being that you are an off-road editor and all.
01-28-2005, 02:33 PM
It is nothing like telling a pilot not to rely on his gauges; apparently you had trouble understanding my post. Here is a scenario to illustrate my point:
You are on a slope, and your clinometer reads a measured angle; you proceed, based strictly on the fact that you are at an angle within specs from manufacturer for your vehicle. One of the downhill tires dips into hole, angle changes instantly to a drastic increase in the position of the vehicle - vehicle rolls over.
Relying on gauges rather than evaluating all components of the hill, including irregularities in the surface, traction on surface, etc., is a recipe for disaster. Just because a gauge says it is safe, does not mean it is safe.
I didn't say don't use them, I said don't rely on them to determine what is safe and what is not.
Understand?
FWIW, most clinometer/inclinometers designed for 4x4 use are useless in a Hummer H1 because they get pinned well before the actual point of rollover threat.
You should not rely on gauges while performing steep ascents, descents, or sideslopes. <HR></BLOCKQUOTE>You can't be serious, can you? I guess the military, state highway departments, forestry workers all are dumb to rely on their inclinometers, clinometers, slope indicators, etc.
I guess their training in using the instruments to help in maitaining safety and not relying on their "pucker factor" is a bad idea to you. Come on, maybe the common idiot will roll his vehicle because he doesn't understand what he is doing but since when is the average person at a disadvantage due to accurate and reliable information like what a gauge would be providing?
Some people are scared at a 15 degree side slope and others wouldn't realize that they are at a dangerous 35-40 degree slope, so how why should one not rely on the accurate information from a gauge. It is likened to telling a pilot not to rely on his gauges.  <HR></BLOCKQUOTE>
01-15-2004, 12:08 AM
The H2 can do 35 degrees side slopes. You must have a some sort of guage at those levels. Never trust your gut when conditions get severe. know how to trust your guages.
Also notable is the question of weight.
R2
Front Locker, Stealth winch, 37" Super Swampers SSR,low center of gravity = Ultimate H2
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
01-21-2004, 12:30 PM
AZ Hummerboy:
Let's see the pic with your "back right tire in the air about 4 feet in the air"
Also, I want to see: "I have also driven down steep slopes, all I could see was blue sky in front of me"  Are you going down backwards or end-over-end?
Hey, I am scheduled to visit Phoenix the week of 7 June. Think we can set up a dinner and an off-road excursion while I'me there? Anyone else interested? I will be on business and won't have my H2...but I can ride along for fun/be a spotter!?!
Ric
OMAHOG/IHOG
Hum2@cox.net
01-15-2004, 06:53 PM
If you're on an incline and can't get your door open due to gravity either you're arms are twigs or the incline is too steep. This is a pic from yesterday. I aired down my front tires to 10 psi and rear to 20 to keep my center down. It was still scary.
One more thing: if you make an error on this type of slope, you're done, it's roll time.
07-15-2005, 12:08 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by sfox:
You did notice that this died like 6 months ago right?
S </div></BLOCKQUOTE>
Maybe the thread touched his/her Hart?
02-10-2003, 01:49 AM
Z, yeah, braking in that situation is BAD. It's your first instinct to do it though, and first instincts are hard to fight. You just need to train yourself.
Braking in certain situations is bad because it throws the weight transfer off, and not in your favor either.
When doing it going downhill, it puts even MORE weight on the front end, and takes the weight off the back wheels. Vehicle can have a tendancy to swap ends when that happens.
AZ, right on man. I do the same exact thing. It's a good idea to pick your line, and to look at the hill and envision how exactly you are going to drive up it. Also, it pays to know whats on the other side.
There's no law that says you can't get out of your truck while wheeling. In fact, I spend more time OUT of my Jeep than in it when I wheel.
1997 Grand Cherokee TSi
It\'s got some lift, skids, and rock rails, among other things.
*member of the \"No Hummer Krew\"*
01-17-2004, 01:50 AM
There were some steep ledges just in front of us. We were concerned if we hit them wrong the truck would go to one side or the other setting us up for a roll so we got out and spotted each other one at a time.
After I got back in to complete the ledge I couldn't get my damn seat belt on because it was locked down, not good when you're completing an incline this steep.
01-28-2005, 05:27 PM
Paragon,
01-17-2004, 01:09 AM
I just have to wonder why did you guys think this was the ideal parking spot?
R2
02-10-2003, 01:47 AM
What I like to do is, I will walk the hill that I am climbing, I will look for ruts, pot holes, large rocks, and how the road is layed out. and I do the same if I am going down a hill for the frist time.
It pays to be safe, out there. And there been some hills I just walk away from.
01-28-2005, 03:05 PM
It is nothing like telling a pilot not to rely on his gauges; apparently you had trouble understanding my post. <HR></BLOCKQUOTE>Apparently you have trouble understanding what you write.
I didn't say don't use them, I said don't rely on them to determine what is safe and what is not. <HR></BLOCKQUOTE>So, saying that a "A gauge will not help you" is not likened to saying don't use them? Also, you didn't qualify your comment as you now would like us to think you did, you simply said:<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Manny:
You should not rely on gauges while performing steep ascents, descents, or sideslopes. <HR></BLOCKQUOTE><BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Manny:
FWIW, most clinometer/inclinometers designed for 4x4 use are useless in a Hummer H1 because they get pinned well before the actual point of rollover threat. <HR></BLOCKQUOTE>Since you are the off-road editor for a supposed Hummer magazine, don't you at least feel you have an inherent responsibility to have the facts straight before you spout your obvious ignorance. Please provide us with where the Hummer H1 has the ability to traverse an off-camber situation that is well past 45 degrees (according to your comment). You are obviously telling us that since Hummer provides that the H1 has a safe off-camber ability of 22 degrees, that H1s can actually easily double that number without fear of rollover.
This is all relatively common sense and simple. A gauge will allow you to assess the situation at which you are at and help determine if it is safe to continue on the same line. You talk as if you have no experience on the trail what-so-ever. You don't magically appear on an off-camber line that approaches the roll-over point. You have to drive the vehicle to that situation and at some point you were at zero degrees and every point in between. If you know that a safe situation to be in is on a 30 degree side slope then as you are driving a line, you "gauge" where you are on the scale from 0 to 30 degrees and drive accordingly. Being complacent about the camber your vehicle is at is what results in accidents. As I asked before, how is having more information available a bad thing?
02-11-2003, 03:00 AM
AMEN....
JJ
01-28-2005, 03:35 PM
how is having more information available a bad thing? <HR></BLOCKQUOTE>EXCELLENT point. I very much doubt anyone would drive off-camber with their eyes glued to the gauge, oblivious to the terrain and the "hole" in it.
The key to Sfox's post is the "practice and experience" part, to qualify NOT relying on the gauge.
For every other non-hardcore offroader (or those on the way to gain that experience) like myself, the gauge is invaluable to provide 'objective' actual angle information, rather than rely on my (most likely erroneous) 'feeling'. Imho.
07-15-2005, 12:09 AM
Maybe it is just me, but I easily understand what Manny implied in his first post. Then again, I don't believe in personal attacks..
JJ
01-28-2005, 02:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by sfox:
I think practice and experience is the only way to know what is gonna turn out bad. I find the gauges a little too slow at times, plus you have to look away from the trail to use them. ...
<HR></BLOCKQUOTE>
Exactly - the gauge will provide you with a reading for "right now" in a situation that requires proactive driving and anticipation of where you will be next. It is perfect for telling you what angle you were at right before you rolled over
Hybrid Mode
