Old 10-03-2005, 12:19 PM
DavidAragon DavidAragon is offline
DavidAragon is off the scale
Anyone miss the different auto settings for the radio/cd player? (normal, spacious, rear, etc)
Anyone know how I can get these back... OR can I customize my own? I see in the manual that the radio can be set to save but I don't know how.
Thanks,
David
03\' Pewter Adventure SUV (sold)
05\' Pewter Lux SUV
Thanks,
David
05\' Pewter Lux SUV
Old 10-03-2005, 12:39 PM
VernB VernB is offline
VernB is off the scale
What year, model did you loose the options?
Old 10-03-2005, 12:45 PM
Klaus's Avatar
Klaus Klaus is offline
In mid-year 2004 GM switched audio systems from the "LUX" to the "Premium" setup. The Premium setup has a lower grade amp which does not have the settings you are looking for.
Some folks on the Avalanche and GM-Trucks forums have successfully swapped out the premium amps for the lux amps. However, it requires some rewiring and programming at the dealer.
Old 10-03-2005, 04:32 PM
... so the newer setup is cheaper? That sucks. It still sounds good but I did enjoy that feature. Probably not so much that I'd want to add parts and pieces.
Thanks,
David
05\' Pewter Lux SUV
