10-22-2005, 08:51 AM
After a day at the mud hole, how do you clean the engine bay? Anything special that need to be done before using the high pressure spray?
2005 H2 SUV (Yellow)
2003 Vert Supercharged
10-22-2005, 12:43 PM
I wash mine with just car soap and a hose. But if you have mud you may want to you a pressure washer.
2005 White Hummer H2 Adventure, Tinted Windows, Hella Fog Lights, Piaa Driving Lights, Chrome Fuel Door, V1, Gobi Rack W/ Ladder and Chrome Steps.
10-22-2005, 01:00 PM
dawn dishwash soap. Or simple green, carwash soap will also work well just keep the truck running and use a shop vac on blow to blow off any excess water that may be in say the battery terminals, or in the battery try, blow out relays and such when your're done powerwashing or using the hose. You also may want to keep high pressure spray away from or directly off the distributor. use a brush and elbow power to clean the distributor. Keep the sides of the truck wet so that the soap doesn't etch into the paint.
10-22-2005, 01:33 PM
I have Radomar our detailer do it
whatever he uses he does a great job....I will find out
10-22-2005, 02:04 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fubar00:
dawn dishwash soap. Or simple green, carwash soap will also work well just keep the truck running and use a shop vac on blow to blow off any excess water that may be in say the battery terminals, or in the battery try, blow out relays and such when your're done powerwashing or using the hose. You also may want to keep high pressure spray away from or directly off the distributor. use a brush and elbow power to clean the distributor. Keep the sides of the truck wet so that the soap doesn't etch into the paint. </div></BLOCKQUOTE>
X2
10-23-2005, 12:16 AM
Thanks everyone for the tips.
10-23-2005, 12:53 AM
you'll want to use the pressure washer first. if you're concerned about the electronics, i would recommend you cover up everything with some plastic bags and tape them down.
10-23-2005, 01:08 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">After a day at the mud hole, how do you clean the engine bay? Anything special that need to be done before using the high pressure spray? </div></BLOCKQUOTE>
Pressure Washer and soap. Job done.
10-23-2005, 01:31 AM
I paid a couple of mexicans to clean the mud and junk off... They did it for 60 bucks at the local hummer dealership.
10-23-2005, 02:01 AM
Location: Bish that\'s not cottage cheese!!! You have a yeast infection!!!
I dunk my 24 inch 5 lb ballsacks in soapy water and start smackin them around.......
Sorry, wrong topic.
I'm touching myself thinking about yellow people.
10-23-2005, 02:04 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Walter_Cronkite:
Sorry, wrong topic. </div></BLOCKQUOTE>
Walter, I told you to lay off the booze when you post.
10-23-2005, 02:09 AM
Peter,
What are you up to tonight?
Wanna swap wives? Same as sharing a bag of pork rinds. Smell the same and crunchy.
10-23-2005, 02:11 AM
Wanna just DP CP tonight and leave the wives with Jim tonight Walt?
10-23-2005, 02:18 AM
I'll meet you in 30 minutes.
....Better make that an hour. Connie's only on her second layer of paint.
