Old 02-24-2004, 03:17 AM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
I am looking at a 2003 H2 withe the front brushguard installed. I like the H2 better without it. Would it be difficult to remove the brushguard?
mbdougl's Avatar
Old 02-24-2004, 03:55 AM
Circuitguy
It takes about 10min to do. Pull off the lower grill plate, remove the four bolts that hold the lower brush guard brackets to the body, if its a wrap around guard you must also remove the upper bolts from inside the grill. Reinstall the lower grill and your done!
BIG-C
White 03-H2-LUX
</a>
Old 02-24-2004, 05:34 AM
MAC MAC is offline
MAC is off the scale
Yes, it is very easy, takes minutes.
In my case, I do not have the 17mm socket, I drove to a gas station, the amigo did it for me for $10. Actually he took it off for me with air powered socket, helped me screwed on the new black grill, and put the brushguard back on, all for $10. A set of sockets will cost me a lot more than that.
Old 02-24-2004, 10:53 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
Do I smell a brush guard for give-away?
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
