Old 09-01-2005, 03:01 PM
Laura Laura is offline
Laura is off the scale
Ok,...Whats the correct way to hit those 4x4 buttons...do you have the H3 in park or netural or what about if your in drive and need to chage traction can you keep it in drive and do it then? I refuse to ask my husband these question cause than i here **** about why i need a better truck than him (Ha Ha) And it does blow away his 4x4 chevy (he he).
laura
laura
Old 09-01-2005, 03:22 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
The manual that came with your truck is pretty good about expalining. You just want to be careful because you can mess something up if done incorrectly and according to the manual this is not covered by warranty.
So if you are in 4X4 hi you can switch to 4x4 lock in drive gear. YOu don't want to drive on assphalt roads a long time in 4X4 hi or extended times over 30 MPH. After 70 MPH it just disconnects automatically. Also, when you go from 4X4 hi lock to regular non lock it may take a little bit to completely dissengage (even though the light says you are normal).
4x4 low you should be in neural or rolling about 2 MPH. Make sure the lights stop flashing before you put it in drive. Put in neutral to go back to hi. Also, the far right button can be turned on /off automatically. This is only on some H3's the Adventure package.
When you press this button the stability control is turned off automatically, I think this option is only on the auto transmission.
The limited slip button (farthest right) isn't really for 4x4 but can be used for snow/ice or sand. When you are spinning your tires when on it will keep from spinning and you loosing control, if off you can spin your tires. Kind off like a race car does, but of course you are not a race car.
Like I said, check out the manual and get used to them away from other traffic. Just remember to watch the lights and don't put in drive until they stop blinking.
Also, the funny sounds you hear are normal. Little gears moving around, in 4 low it will real grind even at slow speeds. Never go fast in 4 low about 15 MPH tops. I think it dissengages automatically at 22.
Most of what I have written is in regards to automatic transmission so someone with a manual transmission may have more details.
I know in a manual transmission you have to have the clutch all the way to the floor to perform some changes.
Have fun!
Old 09-01-2005, 03:34 PM
So in simple terms make sure the H3 is in netrual and wait till the buttons stop flashing to put it in drive and keep watch on my speed according to what i put the 4x buttons on. Is that right....I will read the manual (again)And thanks for the reply with all the info
Old 09-01-2005, 03:50 PM
H3 Hummer's Avatar
Yup. You have it down. And don't worry to much about speed. From the sounds you will hear in low gear you won't want to go to fast.
Old 09-01-2005, 10:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by laura:
So in simple terms make sure the H3 is in netrual and wait till the buttons stop flashing to put it in drive and keep watch on my speed according to what i put the 4x buttons on. Is that right....I will read the manual (again)And thanks for the reply with all the info </div></BLOCKQUOTE>
