12-08-2005, 11:56 PM
I want to run the the tera grapplers 37x 13.50 rim size 17 but the helo maxx 8 wheels i want are offered in 17.9 guess thse wont work or will they?
12-09-2005, 12:03 AM
If the 17.9 refers to the height of the wheel  and I'm assuming it does, then it won't work. I'm thinking the 17.9 is actually an 18" wheel.
05 Pewter Lux SUT, spare tire delete
12-09-2005, 12:12 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MONSTERMATT:
I want to run the the tera grapplers 37x 13.50 rim size 17 but the helo maxx 8 wheels i want are offered in 17.9 guess thse wont work or will they? </div></BLOCKQUOTE>Don't you mean 17x9? I have never heard of any rim being 17.9. Also, they don't make a 37x13.50 terra grappler...you would have to get the mud grappler for that size tire.
If the wheels are 17x9 then yes the 37x13.50 mud grapplers will fit.
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
12-09-2005, 12:17 AM
i meant mud grapplers, and and i also meant 17x9, sorry i took for granted u guys would know waht i meant about the wheel size now what about all this backspacing stuff? do ineed to look for a certain kind of back spacing on theses wheels?
12-09-2005, 12:44 AM
Backspacing is really important when going with new tires (i.e. larger/wider). You better do your homework.
12-09-2005, 12:53 AM
I thought 13.50 wide tires require a 10" wide wheel.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
12-09-2005, 03:16 AM
i meant mud grapplers, and and i also meant 17x9, sorry i took for granted u guys would know waht i meant about the wheel size now what about all this backspacing stuff? do ineed to look for a certain kind of back spacing on theses wheels? </div></BLOCKQUOTE>5" backspace with 0 offset should be fine.
2018 Polaris GEM e4
12-09-2005, 02:06 PM
I thought 13.50 wide tires require a 10" wide wheel. </div></BLOCKQUOTE>
You thought correct. Check tire manufacturer specs for rim width. To small and premature tire wear will occur.
Want-08 Viper, 06 M5
12-09-2005, 04:02 PM
A good 4 wheel drive shop, or even tire shop, should be able to set you straight on this.
12-14-2005, 12:19 PM
I'm running the following with no problems:
Helo Maxx 8 Wheels 17 x 9 with -4.5 backspacking
Toyo MT Tires 37 x 13.5 x 17
12-19-2005, 04:37 AM
I have 17x10 centerlines with 4.5 backspacing on a 37x13.5 Mud Grappler. Rub a tiny bit on passenger side front. If I were to do it again, I would go with something just a touch smaller to avoid the rub.
12-19-2005, 02:35 PM
I have 20x10 with 4.5 backspacing American Racing Mojaves with 37x13.50 Open Country M/T. They rubbed pretty bad at first but after a few turns of the torsion bars, no problems. And, no ride or handling problems at all. I cannot notice a difference in ride whatsoever.
