Old 09-12-2005, 03:00 AM
GamblerHummer GamblerHummer is offline
GamblerHummer is off the scale
I luv my 2005 Black H2 , but I have some major disapointments.
1) The paint job is pathetic, and that is about as nice as I can put it. It is not durable at all. It chips very easily, and the paint job is paper thin. Also, I have all kinds of debri/trash and what looks like metallic paint mist stuck in the clear coat from when they sprayed it. They will not do anythiing about it, becaue they refuse to break factory paint. You can only see if it when the truck is detailed and you look closely.
2) The towing ability is no where near as strong as my Ford f150 CREW. There is just no power at all even in the tow mode when towing anything over 3000-lbs. My mpg also drops down to 9 when towing. This a full 3-4 mpg less than I see when not towing. I only dropped 1 mpg with my F150.
Overall, I love the truck and highly recomend it. However, if improvements are not made in these 2 areas, I doubt I will get one again. I will probably just get another ford f150 crew for towing, or if I have the money a H1.
