Old 11-27-2002, 03:11 PM
Michael James Michael James is offline
Michael James is off the scale
Not sure if anyone really gave a good answer to this definatively...
I want to replace the existing headlights and foglights. Are there any HID bulbs that you can just drop in? no extra wiring, etc..
What are the sizes? Do they do both high and low beam?
What about these and where can you buy them?:
IceWhite Platinum Xenon (has anyone actually installed them)
Sun light
PIAA X-Treme
Hiper
Sun light
PIAA X-Treme
Hiper
Old 11-27-2002, 06:19 PM
BreathlessPerformance.com BreathlessPerformance.com is offline
Supporting Vendor
BreathlessPerformance.com is off the scale
Michael
We do the headlights as a direct plug in. The system we have is only for the low beam. They make a low and high unit but it very deceptive. They use a small motor to move the angle of the bulb to produce a different focal point of the beam. It does not increase the light output plus you have to worry about a motor inside the bulb that has to move back a forth.
Hope that helps.
Thank You, Ernie
